making projectors - Exterior Forum
making projectors
Tuesday, January 31, 2006 6:59 PM
Is it possible to purchase a set of 99 cavalier projector headlights from ebay, and take the projectors out of them and use them to retro fit the 2002 cavaliers headlights?
Re: making projectors
Tuesday, January 31, 2006 7:08 PM
ebay projectors are cheap, and it will probably mess up if u take them out, just buy the projectors off IZN TRBL he sells the projectors so u can then fit them into ur headlighs and do ur own work,
here's link
CLICK ME BITCH!
01 2200.
Tuesday, January 31, 2006 7:11 PM
ya, i know he makes them, i just dont feel like paying 500 bucks. i would rather come up with a less expensive alternative. I guess ill just keep my eye out for projectors around work.
Tuesday, January 31, 2006 7:17 PM
jwagg wrote:ya, i know he makes them, i just dont feel like paying 500 bucks. i would rather come up with a less expensive alternative. I guess ill just keep my eye out for projectors around work.
read the post again he said buy the PROJECTORS not the headlights.
Tuesday, January 31, 2006 7:25 PM
good call.......i forgot he sells the projectors.....hmm....this might be a weird question, but ill try. If i purchase them, and i retrofit them, what ones would i buy if i wanted to use a 9007 bulb? IF i convert to HID, would the HID bulb fit into the 9007 hole if i buy the conversion kit? Is there anywhere like a tutorial that gives tips on installing the headlights yourself?
Tuesday, January 31, 2006 7:34 PM
actaully the 440 istn that bad.......for him to build them, plus its alot less hassle
Tuesday, January 31, 2006 10:25 PM
jwagg wrote:this might be a weird question, but ill try. If i purchase them, and i retrofit them, what ones would i buy if i wanted to use a 9007 bulb? IF i convert to HID, would the HID bulb fit into the 9007 hole if i buy the conversion kit? Is there anywhere like a tutorial that gives tips on installing the headlights yourself?
There is not a projector that takes a 9007. You can get a projector that can be converted to HID very easily later, but your going to need to change your connector on the wiring harness. I think IZN TRBL sells the Valeo units, which are available either halogen or HID, and there is a part that you just install on the back to convert to the HID. Talk to him about what he can get. He can probably answer all of your questions.
Wednesday, February 01, 2006 8:48 AM
The "Josher" can also send you the materials, you then can make them yourself.
