I have a 96 cavalier sedan, will a 2000 cavalier sedan front bumper be a direct bolt on?
when it comes to boobs i need a girl with bad grades cause im tired of all the ones walking around with straight a's
Yes and no...
You will need to do some filling around the headlights for it to fit.  You may want to get 2000-2002 headlights as well for the direct bolt on.
yes but then you would have to swap out the headlights and corner lights because they are different.  also you would have to cut off the corner bracket on your fenders and put on the 00-02 corner bracket.  then it would probably be easier to just take the wire harness from the 00-02 headlights and use that since your going from 2 bulbs to 1 bulb.
but yes the bumper does bolt directly on, its just all the other little stuff you have to do w/ it
I found out the hard way.. the wiring harness for your headlights wont plug into a 2k+ headlight harness.. youll have to splice your wires with the new headlights
BaggeDCav98  (Unquotable One) wrote:then it would probably be easier to just take the wire harness from the 00-02 headlights and use that since your going from 2 bulbs to 1 bulb.
Just a correction, the 00+harness cant work in 95-99.. connectors are difference sizes(look in pic below) Me and karnage found this out the hard way last weeked.. Now the people i talked to said they used a 95-99 SUNFIRE harness.. Tommorrow im going to pick one up off a parts car and try that.
its2nv4 wrote:has anybody made a fiberglass lip underneath the headlights w/o having to do the headlight conversion. in case you wanted to keep the pre 99 headlights.. im considering it myself but just wondering if anybody had any pics of this done.
The bumper is a ABS plastic type material if i remember correctly, so getting fiberglass to stick and stay will be a lil harder than if it was fiberglass. But there is a lil groove for teh 2k headlights to sit in which if that groove was extended all the way to the corners then u would have the right hieght and the lip u need for the 95-99 headlights, maybe take a foam block and make the lip with it(as a mold) and thenglass it to the bumper on the front and get the front how u like it.. then go in the back(IF u want) and cut out the foam, or leave it there for structure/support.. and just glass teh back closed. but remember when u glass u will make bigger, so if u make the foam mold you will need to shave some off the final to give enough room for the fiberglass to be laid.  I dont know much about glassing so i dont know how to pull off getting f/g to stick..
