i got a pair of M3 mirrors with the LEDs in them. I was wondering if ne one has ever swapped the lights in them, if it was even possible
i want to put aqua ones in to match underbody and interior
i want 2 put some whit 1s in but i dont like 2 mess with leds but it would be cool. i wish some1 did a write up or atleast some tips.
http://www.cardomain.com/ride/789103
All you have to do is find the same type of LED that is used in the mirrors, take the PCB out of the mirrors, de- solder the old LEDs and re- solder the newones on. Its pretty easy to do, your going to need a soldering iron some solder and some de- soldering ribbon to get the old solder off. Make sure you use a green or red scrubby on the contacts after you de- solder the old LEDs.
[quote=ŠleveŽ One]All you have to do is find the same type of LED that is used in the mirrors, take the PCB out of the mirrors, de- solder the old LEDs and re- solder the newones on. Its pretty easy to do, your going to need a soldering iron some solder and some de- soldering ribbon to get the old solder off. Make sure you use a green or red scrubby on the contacts after you de- solder the old LEDs.
do you know what type of leds the use or how i might be able to find out.
I would say its safe to assume that they use 3mm LED for there application. go to lsdiodes.com and check that out, they have info there too. I was looking inside my LED mirrors and it looks like the resistor(s) are already soldered to the PCB which is holding the LEDs in, so you shouldnt need to buy resistors.
Hey Arnjolt, How did you get the clear lense off your mirrors to get to the LEDs, does it just pop out?
You've got to take the whole mirror off. Pop off the mirror from inside, then if you've got the motorized M3s you'll have to unscrew that then you can get at the LEDs
http://www.cardomain.com/ride/676422/1
arnjolt, did yours bunny ear upwards like all the damn ebay ones??? i hate the fact that i wasted 30 bucks on mirrors that look like CRAP.
this useless post brought to you by the alcoholic known as LUNDiS
lundis wrote:arnjolt, did yours bunny ear upwards like all the damn ebay ones??? i hate the fact that i wasted 30 bucks on mirrors that look like CRAP.
happen 2 me 2. i hated that i took them off put my stock 1s back on then i bought the APC m3 mirrors. they dont stick up like bunny ears.
I never actually installed them. I bought the F1 and M3 at the same time and only put on the F1. I took apart the M3 to see how hard it would be to change the LEDs and left it at that. It's still in pieces in my basement
i have mine apart, and mine have 5 mm ones, and i am replacing them with brighter ones........
if you want assistance with that, let me know...........
wait for it... wait for it... NOW GO!! ---> '02 LS Sport <---
Yahoo IM : buzz122 AIM : buzz122cav
