ok ive read up about the ebay projectors and i heard there not that great but... in my opinion any kind of hid setup will beat up on a stock setup... now what im wondering is how was the fitment of these...
i want to get some ebay ones that fit and the clear corner also fits... so it looks stock like, and not bulgy like some do... i know someone on here owns.
what do ya say? give me a review of the product.
horrid. and hids will eventually melt te houing (since they were made for halogen bulbs)
turdfire wrote:horrid. and hids will eventually melt te houing (since they were made for halogen bulbs)
Wrong and way wrong... Really you don't know what the hell you are talkin' about.
If you want to get these you will need to swap the stock backing of the lights onto the new projectors. If you know anything about HID's they are only 35W bulb instead of the higher stock bulbs. Just FYI
Drivers Side :
Passengers Side:
Need I say anything more?
oh wow.. they dont fit at all
right...well all i know is mine fit like crap.
get the one piece headlight/corner if your 95-99
1998 Chevrolet Cavalier
5-spd
Hey everyone! Did anyone read what I put on what to do? Put your stock headlight mounting bracket on the new headlight. You will thank me later.
If not PM me if you want to get ride of them cause I'm looking for some for my 95.
TRD Cav Fire are you refering to jus the mounting brackt or the entire backing of the hadlight assembly and all?
~Boost. Its what's for dinner!~
I just slotted out the mounting holes with a drill, worked like a charm, the only reason they dont fit right is beacuse of the projector being larger than the stock housing, it hits the framework behind the lights.
I slotted the holes so that I could move the lights forward and they fit like a glove.
Mine fit like @!#$. Im switching out the brackets saturday and it should be fine. Just plan on doing a lil modification but its not to bad
so your saying they would be fine to use with the hid kit in the gp
well they will work but you do have to do some work. My passenger was fine, drivers was a different story.
they should be fine....If not you could always checkout this site. its a great source for your projector needs and hid needs.
didnt know ebay actually made projectors , its good info to know
Timothy Pietraallo wrote:TRD Cav Fire are you refering to just the mounting bracket or the entire backing of the hadlight assembly and all?
I'm talkin' about the entire bracket behind the headlight. It should only be 3 maybe 4 bolts to take the headlight from the bracket. I hope this helps
[quote=97cavie24ls(JDM&00s/c sedans™)]didnt know ebay actually made projectors , its good info to knowLoL you didn't know! They even make cars from what I hear at Ebay Motors. Check it out man.
Eric you are the man you know that....
I know 2 people with them and they fit just fine, no modding. They're from eBay so maybe you guys just got the defective ones.
Lance Sharpe wrote:I know 2 people with them and they fit just fine, no modding. They're from eBay so maybe you guys just got the defective ones.
Wrong! The problem is that the companys that makes the lights don't have a Cavailer sittin' around to test fit and adjust them perfect. This is why I say use your stock brakets cause they are adjusted to your car as of now, and just swap over the new projector housing to your stock brakets and bolt them up. You will just need to maybe do some small adjustments. Anything you put on a car always needs some adjustment.
If you guys don't want to do what I said I will buy some BLACK housing projectors with black corners off you for cheap.
Ok you can be 2nd since this is your post, but it was my idea first.
