I have an 97 GT and the turn signal is burned out(round one).How do you get to the bulb.Do you take the black trim off in the wheel well or from underneath.Also,does anyone have a number on the bulbs,been to a few places none have the amber bulbs,Thanks
easiest way to get to it is to remove your headlight....bolts are 1/2
I may run 18s, but I can do your taxes in 10 seconds flat.
yeah take the headlight out, thats the eastiest/quickest. as for the bulb size, i just changed my turn signal lenses the other day and looked but i cant remember the number exactly. i would suggest take the bulb you need out and then using that to find a matching bulb ( i also believe that the bulb number will be on the bulb. if all else fails, you can call up a local auto parts store and they should be able to look it up for ya.
