whats up Jbody? just have a quick question: Is there an install forum on here for Verical Door kits? I just bought one for my 2002 LS from www.soundspeedsports.com. Just wondering if there is a step by step install on here specifally for Vertical Doors. THanx everyone.
thanx bro..i appreciate it..im looking to get some Halos for my 02 soon from that site too
Hey does anyone know how to make homemade custom vertical door kits? I don't have the money for those expensive ass kits so if anyone knows let me know
***Looking for a BLUE 03+ STOCK cavi wing pm me if ya got one you wanna sell***
I got all that so what do I need to do?
Ok what you wanna do is hack off the door hinges, melt all metal smooth in teh fender well area with the tourch. THen weld the doors on at the 90 degree angle and your done
Oh yeah 1st step put the gum in your mouth.
Seriously its cheaper to buy the kit instead of making your own. Unless you have access to a cnc maching and know how to design them.
Disclaimer:
Dey see me Trollin' Dey hatin' for trollin dey trying to catch me ridin dirty.
^ lol.
Don't attempt to make it yourself please....save up and buy the kit! You can find it for a pretty damn good price now.
So IZN on the VDI kit you put the shock on last?
yes sir. after mounting the shock, you can then line and adjust.
good luck fellas!!!!!!!
-Www.IznTrbl.Com-
when you take off the fender, do you need to remove the corner lights to take off the fenders on Cavaliers?
ohh..... the cavi guys will need to help you out here. LOL
i's gotta fire.
-Www.IznTrbl.Com-
lol thanx tho for the cardomain link man, it'll help me out forsure..appreciate it....i know for the sunfires you need to, but i dont know if you need to for the cavaliers
Ok cool thanks. Just bought a used VDI kit from a friend. I take it you need the friend to lift the door up once you mought the brackets and then add the shock correct? I am guessing that is the way. Cause it would be hell to try anything else it looks like.
the corner lights are attached to the fenders...
Yes you will need a 2nd person to lift the door in the air, and hold it in place while the other person installs the shock.
I installed my kit myself, but the shock would be impossible to do alone.
okok last question..lol.....i phoned soundspeedsport and they said I would need to cut of a little piece in my fender for the vertical door hinge to fit in proparly inside of the fender..is this true? i was looking at Izn Trbl-[ahys·in] [truhb·uhl] Link and there was nothing about cutting anything for the fender
yeah this is true there a little flap that sits closest to the door.. use a dremel tool with cutoff wheel to do it..
takes two mins.. nothing crazi..
later
and goodluck!!
OEM CAMBER/CASTER KIT 10 People for $210 <P>
GOT ECOTEC?
big poppa wrote:the corner lights are attached to the fenders...
The corner lights aren't attached to the fenders... at least not on that 2002. They simply clip onto the headlight. Regardless, you'll want to remove it.
Sold 6/30/06.
i installed the drivers side door this morning...found a few problems with the install tho. When i went to extend the wires and try everything out, everything works perfectly except for the drivers side power door lock..it doesnt close or open when you press the pad. Another problem is that when I go to open the door, it hits across the fender and doesnt want to open the door, I have to move the door up a slight bit to open the door..can anyone help me out here with the fender problem and the wiring problem? greatly appreciated
Sounds like it's time to check everything over. Recheck your wiring, esp since your passenger side works. As for the fender problem, I'm not really following. When you go to open the door regularly it rubs the OUTSIDE of the fender? Like as it is pivoting inward?
Sold 6/30/06.
its ok David Morris..i went over all the wiring this morning again..there was 2 wires loose..so now all the power locks/mirrors/Alarm/Locks work perfectly again....and I fixed the fender problem ( Thanx keith)...the doors are awsome..just have to get used to them i guess..lol..i;ll b doing the passanger side door next week then take some pics n post..thanx to everyone that helped me out from the beginning
//oops..my bad..lol Norris..i figured it out man..but thanks n e ways man
