can any one give me specific directions on how to do the Flip Flop Trunk. i have a clue from a couple threads, but they arent the best directions.
thanks
yeah man those instructions are good and know what their talking about if u need any extra help u can hit me up on aim my screen name is dragonthug42484
the only thing about those instructions is that the pics were too small. Does anyone have any bigger pics?
Click on my sig to check out my CarDomain site. Enjoy!
i can look trhu my install pics and see what i have, its not hard, i didnt use pics or anything, just thought logically and measured 2x drilled 1x and all is good
Leaks??????, flip flop trunk mod makes your trunl leak, I thought the trunk would sit the same when closed as it did in its oem state before being modded for the flip flop look. I was kind of interested in this, but if it causes the trunk to leak, thats all bad,lol.....
98 j-body sedan
some leak some dont, i did mine when i got my fire 3 years ago and still have no problem with leaking, as do the couple people i know who live around me that have this done
i;ve had mine done for about 8 months and have no leaking problems
i just recently installed the flip trunk. and i looked at the pictures online of others. my problem right now is that the two corners stick up about an inch. i have the screws that hold the stock trunk hinges(by speakers) in with 2inch spacers. should i change the spacers. Also, the pictures of the green cavalier, it shows that the 2 trunk bars that are crissed cross by the stock hinge, it shows them all the way on top, does that matter, mine are on the middle one?
tell me what you think and how you can help. if possible, i can take pictures so you guys can understand some more
^^Which is what BaggedCav meant about leaks... If not done right, it'll leak...
The cross-bars are used for tension holding the trunk open. Would be no different than if you had the gas struts on a 'vert
what about the 3 screws on each side holding the stock hinge. are they down to far, or not far enoguh. i have them down 2 inches.
The only thing i can say it to go 2 Autoloc.com and look at their manual cuz thats the only place i've seen em
