Got a small hole, thought id intice you with the shaved in the title. Anything I can buy to fill in a small hole? About the size or a quarter.
is it from rust? and where is it at?
If it's an actual hole the size of a quarter, and it's on metal - weld it.
ya what he said, you don`t just fill in a hole with "bondo", or fiberglass fill it with a piece of metal, then ya have to weld it in so on and so on
can i haz bondo
Depends on where the hole is located. There is body panel glue that holds up really good, but welding is the best way of doing it.
filler is used to fill in small dimps in body work and make the body smooth, its not used to fill holes. holes have to be welded closed to be done right
no welder suggest something else
go to a body shop and get it done right. thats all im going to suggest.
Darren Reynolds wrote:no welder suggest something else
no one said you had to do it. take it to a shop and get it done
