there arent any halo LED head lamp kits on ebay for the 00-02 cavys there are only the 95-99... would these fit my 01 z24 and if so does it cover the corner lenses as well? it looks like it should
thanks guys
they will fit but you will need to switch over the bumper and fender bracket, also you will need a wiring harness for the headlights since you are going from 1 bulb to 2. the 95-99 will fit your 01 but you will have a gap under your lights if you dont swap the bumper
ouch...ok well do they make halo kits for the 01? im assuming not im just checking....
no but josh (izn trble) can make you a set but they are pricey but well worth the money
Or you can make some mods to the 00-02 brackets and make a spacer to fill the gap and it will look good enough. What do you think?
See this.
And this.
Hope this can give you some ideas.
Later
the spacers look out of place imo
those spacers actually dont look too bad. throw a set of josh's eyebrows on them and if they would wrap down to the bottom there and meet those spacers, that would look pretty cool.
Injection is nice but id rather be BLOWN!
Yes, I thought the eyelids woulb be an alternative to complete the job. Still thinking and seaching. Thanks.
how would u install the Red Cold Cathode Angel Eyes? does the headlamp assembly open up?
Yes Mike, the assembly could be opened but the angel eyes come with the kit already. It's a one piece assembly for 95-99 i got from ebay. I installed mine swapable, I mean I can switch to the original headlamps in ten minutes or less because I prepared them to be plug and play. They are plug and play for 95-99 cav's but not for 00-02, you have to decide if you go swapable or permanent. I did switchable because as you, I'm waiting for a 00-02 OEM style projector headlight set too. I showed you mine as an alternative to but there are other choices. IZN has some of them and I think was whiteboy sho was offering a good choice too a while ago so, It's up tho you how you want to go. If you have any questions let me know.
