theres a spray... 3m makes it...
POR15.. its paint on. not rubberized tho.. Its what i planned on using.. friend that used it said it doesnt have a odor so i was gonna use it throughout the interior and trunk, aswell as the underbody, wheel wells, and some suspension components. If it is a area that is in sunlight u will need to put a topcoat on it which is like a protector.. but everywhere i planned on using it is either under the car or will be under sound deadening..
http://www.por15.com/
i dont know if u watch Trucks! on SpikeTV but they used this on teh frame of a S10 they were workin on.. plus u can get it in small containers so u dont worry about opening a big gallon and it start to harden in the can..
btw.. any particular reason u wanted rubberized?
I've used POR15. It's expensive, but it's meant to be painted over rust (hence the name POR) and once it's applied anc cured, it stops rust dead in its tracks and it's practically indestructable. I'm going to be painting the rockers and what not on my car when I fix the body damage for that very reason. 200K miles of harsh Iowa winters does wonders to a car's metal and POR15 is the antichrist of rust protection lol. If you use it, make damn sure the entire surface it's being applied to is clean and completely dry. And whatever you do, don't let any moisture - water, rain, sweat, your beer, dog slobber, whatever - get into the product. If it does, the entire can is ruined and you'll have to get another. Theis stuff is designed to repel moisture when it's cured, but in a liquid state it's like a spong and will suck up moisture instead. This is why I recommend
A: buying it in smaller containers, you can buy it by the pint or by the gallon, get the pint size, Worst case scenario, you ruin a pint instead of an entire gallon.
B: doing this in conditions that will prevent moisture from getting in the product. Cool weather, maybe in the shade or air conditione dgarage so you're not sweating your arse off, wear long sleeves and gloves, even a hat or a sweatband, whatever you have to do.
It can be rolled on, brushed on, and I'm not entirely sure, but I think it can be sprayed on too. I've only used rollers and brushes though so I'm not entirely sure about that one.
just get ur car Rhino lined , i know Eastwood carrys undercoatings so check them out , and if u want to order with Eastwood let me know and i can just drive to there store here in PA
ShowOff Customz
03 Cavalier
73 Beetle
68 Fairlane 500
This isnt a bad idea... I might have to add this to the project list!
Joker 0387Escort wrote:just get ur car Rhino lined , i know Eastwood carrys undercoatings so check them out , and if u want to order with Eastwood let me know and i can just drive to there store here in PA
I would agree with you about the rhino liner.. but I prefer Line-X
... Rhino sometimes can be peeled off if you pick at it hah ( used to work at Line-X and had to do repair jobs sometimes it sucks )
Thanks
Shaun
www.ShowStopperTuning.com
im sure if you get your trunk Rhinoed it would help out with having a box cuz itll act like a sound deadner and might even be better. i had thoughts of useing rhino or line-x on my 87 EXP so that it wouldnt rust
ShowOff Customz
03 Cavalier
73 Beetle
68 Fairlane 500
Lizardskin; the stuff is 1) heat resistant, 2) sand able and paintable, 3) can act as a soundeadener, 4) waterproof, 5) can be sprayed anywhere on the car to act as a "undercoating" / protect ant, ect, ect. The stuff is great!
You can check it out at www.lizardskin.com
By the way, and this is just my two cents, I do not believe that POR-15 is a good avenue of approach. Much like one of the previous responses to this thread said, POR-15 is used more along the lines of the treatment / covering of rust; not a as a means of prevention. On the other hand, Lizardskin is meant to work in the exact scenario in which your going to undertake. Consult the website, and I think you will agree it is what you are looking for.
Good luck with your project.
I am sorry, but I forgot to mention that lizardskin can be rolled onto any surface. Just bare in mind that you must adhere to manufacturer recommendations as far as the thickness of the application. Which I believe it is about the thickness of a credit card.
As far as spraying the stuff; its a relatively thick product, and either you can mock a "paint booth" in your garage by sealing the car inside with some large sheets of plastic and tape. And because it is thick the potential for overspray is low. At least when compared to common automotive paints and primers.
Sounds like you can apply it with a brush.
Sound Control Application
LizardSkin® SC is being used by custom car, street rod, truck builders and RV owners who want to reduce unwanted noise and/or enhance the sound of their high end audio systems. It is best applied by special spray gun to a clean and dry primed or painted rust-free surface. Typical applications include firewalls, floor pans, transmission tunnels, doors, hoods, trunk lids, under headliners, inside fenders, panel van walls and other areas which generate vibration and noise. It may be painted if desired, with no loss of acoustic performance.
