I want to install a lambo door kit this summer, preferabley the MMS kit, I know james molpus has them, but does anyone else have lambo's that can tell me some info about them. any problems? hard to install? I just want something different in my town is all. any help would be great.
thanks!
awesome product form MMS i have them no problems
did it in a total of 3 hrs.. both doors but it was my fifth set..
it may take you 5 or 6 hrs.. take your time do it right .. use the search button. and look for lambo install instructions.
OEM CAMBER/CASTER KIT 10 People for $210 <P>
GOT ECOTEC?
they up pretty easy and come down easy? or does it require a lil strength to move them up and down?
They go up pretty easy but require a bit of strength to get them down. It also depends on the weather (cold =easy down, easy up hot=very easy up, hard down). Fairly easy install, took about 4 hours (2 1/2 for the first door, 1 1/2 for the second) and wasn't too hard. You'll need to adjust them once their on which takes the most time and concentration so be prepared for some headaches.
* Student of the University of Oklahoma. Go Sooners!
dosen't sound to bad, I'm sure it can't be to awfully hard to move them down, but I may have someone help me install them cuz I'm not mechanically inclined at all lol.
ya the install isnt to bad at all.. like stated just look for the install instructions... the hardest part is lining them up.. thats a pain..
you all are very helpful. thanks a lot, I may just have to order the kit this summer, just want to be different!
with no knowledge or instructions, i put mine on by myself(no help at all) in about 2.5 hours
the longest part of installing lambos is extending all the wiring to be honest.
I don't have power locks or windows so I should be good then?
yeah all you will have to do is extend your speaker wires.
its easy to do
^^ya, then it should only be 2 wires
oh but get a friend to help you it makes things alot easier!
I plan on it! always up for a lil help.
in my buddies 01 we installed.. said u needed to extend wires.. we just pulled out the grommets for the wires and there was enough to were didnt need ot extend wires.
also when u guys are mentioning aligning.. if u leave the door on the car there is little to not aligning adjusting needed to get them to line up.. just have a friend relax and lean up against the door while u installed the hinges.
i think it took us bout 4hrs total MAYBE to do them, with 3-6 of us who had never done them, and one of the bolt studs for the hinges was bent from a previous accident so effing with that and bending that back took teh longest time.
btw for those of u having problems blowing struts there is a company that makes replacement shocks that work, i dont remember the site but my buddy jeff just got his new ones yesterday(should be installing today) so ill find out where he got em. im assuming there better anyway..
who did you get your kit from manta Z?
stephen its lambofever.com and im glad your getting all of this practice you can come down and help me when i get mine
honestly...i think my lambos were easier to install than most of the stuff ive done, and i do ALL of my own work
i taped the door on, removed the fender, and swapped the stock hinges out for the lambo. thats it. bolt it all back up and done. no aligning needed. fit perfect, closed perfect. very very simple
curious how do you take the hinges off if the door is closed?? i have the mms doors and i have been hinking of selling them since everyone says that they never sit right..phil
cuz at this point u should have the fender off which exposes everything. the stock hinges, the wires, everything
ill try and grab a pic tonight if i remember, as i still have 1 fender off
I also have the MMS kit, easy install had it for 2 yrs. I had the Decah kit before and it was a nightmare.
Not a bad install like they said. It took my dad and I a couple days, the hardest part was taking everything off to get to the hinges itself, then the wiring took forever like big poppa said. I had the doors adjusted perfect, until i got hit and had to get a new door, now its not lined up perfect
..its a pain now, but still looks cool
overall easy install man, not as hard as i was thinking.
