I picked up a GM Ftonr lip finally
Question is my 2000 Z doesnt have the proper slits in the bumper
I was wondering what you guys have done to install these lips?
My car is lowered with Sportlines and AGX's so if possible id like to be able to remove the lip when needed if i can
Any suggestions
Thanks guys
I have the same question. I purchased an aftermarket z24 front bumper to replace my broke type j, but i have a front lip that i want to put on it and there is no slits and not sure how to line it up.
Well really it is as simple as you put the lip up to the bumper and cut some slits in there to let the tabs go in. The GM clips that hold those up are like 3-5 bucks each.
Most people since the clips somes fall out they JB weld them on, or put something eles on them to help hold them on.
I have a tab or 2 missing on my Lip
Thats where the problem is
Any other suggestions?
I found a bag of clips from the guy i got the lip from
Any other suggestions for install?
Do i also need new fender liners if my car doesnt have the slits in the bumper?
Edited 1 time(s). Last edited Sunday, March 11, 2007 8:57 PM
remove the bumper from the car. flip it upside down. Line up the lip where it fits best. Mark where the tabs are, and make the slits. On mine, I then used a heat gun, or other heat source, and melted the tabs down. The lip held on great for a long time (even after I traded the bumper
) Never had a problem with it, even lowered on DropZone springs, and running around in WI winter.
SPD RCR Z -
'02 Z24 420whp
SLO GOAT -
'04 GTO 305whp
W41 BOI -
'78 Buick Opel Isuzu W41 Swap
i just put the clips in after cutting the slits. havent had any problems... i didnt even screw everything back in and it still holds...
I understand cutting slits and that whole part of the deal, my problem is the ends of the lip. Dont know if these pics will help any.
a buddy of mine just pl premiumed it on and it never came loose
cause i know i can cut slits and epoxy it in i just want the end to be clean looking and at least somewhat flush
from the pics that looks like it doesn't even line up at all but .. who knows
Most of the clips on the one side of my lip are broke
Well why dont you just break all the clips off and then line up the hole from the lip with the one on the bumper. Then drill holes in both and use zip ties to hold it onto the car. This way you can cut the zip ties when you want to take it off.......Thats what I might do I haven't taken my front off yeat to see how verything is going to line up.
i got no tabs on my front lip, ive got 2 screws in the fender wells, and 2 bolts in the middle holding it (had 4, but 2 of them came loose when i scraped, also some epoxy where the bumper curves so it stays flush.
I want to share something with you - the three sentences that will get you through life. Number one, 'cover for me', Number two, 'oh, good idea, boss', Number three, 'it was like that when I got here.'
