maybe i am a comlete idiot but one of my headlights burned out in my 02 z and i cant for the life of me figure out how to get the bulbs out, i removed the two screws that hold the headlights in place under the hood they only wiggle around a bit. what else do i have to do so i can change the bulbs, thanksguys
'spit chew hits soldiers boot'
"thats a real nasty habit you got there"
"this stuff will make you a sexual tyransaur just like me"
jesse the body ventura in Predator
If they are like the 03 + cavs, after you remove the 2 bolts you have to PULL because there is a metal clip that holds them in place.
you have to stick a long screwdriver in the a slot to push & release the corner markers, take those out then the headlights will be able to lift out & then you can access the headlight bulbs
what slot are you talking about to stick the screw driver into? i just dont wanna bust my headlight housing.
between the headlight and corner light
bewtween the headlights and corners there is a clip thats holds them together just stick the screw driver down in there and push hte clip apart , u will see what we are talking about once u look down there ....first time i ever did it i was like WTF ..i took oyut every bolt i could find and still wouldnt come out . LMAO
all you have to do is unscrew the headlight and pull thats what i do and the headlights come out fine..
ok thanks guys
