i cant explain it but i will send you pics cause it is really easy to do.
i didnt even need to put poppers in. i just hit the button and the pop open about 4 inches out on their own. my lambos might have somethin to do wit it. i dunno.
I NEED a 97-99 LD9 engine harness for an auto.PM if u hav info.!!
mad mike can you send them to me too?
Mine are mounted directly under the striker that catches the door latch on the body of the car, though it's a few layers thick I felt it was the best location.
rednine7 wrote:i didnt even need to put poppers in. i just hit the button and the pop open about 4 inches out on their own. my lambos might have somethin to do wit it. i dunno.
so u just have the shaved door kit?? with no poppers? thats what i wanna do..i dont want poppers to throw my door out. id rather it just unlatch and ill open.
^^^ That's the way mine worked as well... The rubber gaskets had enough spring in them to pop the door open a few inches, and I just grabbed it from there.
www.TaillightTinting.com #1 SOURCE FOR VHT NITE SHADES
www.aPlusPerformance.com BACK ONLINE SOMETIME SOON!
PHONE 763-682-9945
Mine dont swing my door open, opens just a tad so I can grab it..
Joey Baggs (Eazy716) wrote:rednine7 wrote:i didnt even need to put poppers in. i just hit the button and the pop open about 4 inches out on their own. my lambos might have somethin to do wit it. i dunno.
yea bro. just the spal kit installed.i didnt want to put the poppers on either so we tried it without the poppers and it swung the door out a good 4 inches or so with more than enough room to grab the door.
^^^excellent man....that info is much appreciated!!
no prob
my buddys on him neon just open it a lil bit so that he can fit his fingers between the door and the car and he can open it
13.1 @ 115
hope this help
mcmoney wrote:hope this help
Mine are in the same location. However I noticed they're adjustable.
If you could do me a huge favor and measure from the body to the end of the popper I'd greatly appreciate it!
I dont think you need poppers on a J. I dont have any on my car either, I just have the little "actuators?" that unlatch the door, and it opens all by itself. and trust me, my doors are HEAVY, afterall, they have a metal bar welded on........ and they still open.
thats where mine are
mine olny open about 6 inches
howd the install go? I'm about to install my spal kit on Wednesday / Thursday this week.
big poppa wrote:howd the install go? I'm about to install my spal kit on Wednesday / Thursday this week.
i dont know havnt gotten to it yet lol ended up working on the motor that day instead and now im working out the problems on it. hope to take it for its first drive this weekend, but im about to leave for chicago for a couple days for work so i probalby wont get to the poppers till the weekend after this one. if you get yours done throw up some pics to make it easy on me lol
SPAL kit was an easy install IMO, I even did the trunk release option as the shop whom installed the Viper had neglected to. So I figured why not, it only required a relay and a little extra wiring.
I wired the majority of it up in the living room, marked what went where, mounted the unit in the car, hooked up the power, grounded it, and ran the solenoid power out to the doors. I installed the box where my passenger airbag used to reside. Plenty of space in there, plus made running power etc. a lot easier, and very well hidden.
use the poppers it always be a level surface you are parked on, use them trust me
'spit chew hits soldiers boot'
"thats a real nasty habit you got there"
"this stuff will make you a sexual tyransaur just like me"
jesse the body ventura in Predator
install was easy. took a few hours to install them. just make sure u put a wire through the lil loop for the lock or just disconnect the lock period. wouldnt want it to lock on accident. and as for the poppers, just install the kit first and then see if u need them. ive had my doors shaved for about a few weeks already and been on all kinds of hills,ramps, driveways, etc. and i have no problem opening the doors without the poppers
i had the shaved kit with poppers on my old pickup (mazda B2200), and since i didnt want alot of swing in the doors i mounted the popper itself in the door jamb, between the hinges. i found it gave just enough push to the doors, while still being out of view. id rather not see the popper when you open your door.
