How do you take the doors off a 2002 cavalier? I know its all the same for every year. And will any 95-05 door fit? thanks very much
-alex
Caviracer02 wrote:How do you take the doors off a 2002 cavalier?
Unbolt the hinges...
-alex
You answered your own question there...
The hard part is that they are heavy and you will need some help holding them in place when you put them back on.
you will have to pull the fender off
matt wentz wrote:you will have to pull the fender off
You dont have to pull the fender off. Just be carefull when you are removing the door cause it is very heavy, so have help.
ya man, pulling the fender off isnt necessary. makes it easier, but not a must
YOu will have to take off the inside door pannel to disconnect your speaker wiring. You may need a special tool to get the window handle off also. You can get those at AutoZone and they aren't expensive but worth getting.
i just took off my doors and never messed with the fenders. It wasn't all that difficult.
To put my lambos on i took the fender off it made it alot easier. U also will have to cut all those wires to get the door off. J ust a hint that part sux
13.1 @ 115
