i did the 00-02 front end swap and now my head lights are a mess one headlight is dimmer then the other  my turn signals  stay on and blink really fast  my DRL would flash  but i disable those thinking that was the problem . i strait  wired i didnt use relays .i used this diagram
http://www.j-body.org/forums/read.php?f=7&i=342624&t=342624 to wire .i cut ,spliced ,solder the taped the wires .idk what the problem is  any help would be great  this is my daily driver  and i work at night  i thought i be the lucky one and have no problems
You need to buy 2 relays from the auto parts store.
You also NEED to buy 2 new headlight wiring harnesses, do not use the cheap junk RK Sport ships you.  New ones are $6 a piece and will save you the $75 for burning up your headlight switch when the RK Sport harnesses overheat, melt, and short out.
Here are the instructions to fix your lights:
2K headlight conversion
Take your time and do this one step at a time.
^CLICK ME TO SEE HOW I BUILT EVERYTHING^ How To in Interior Forum
If the pigtails you got with your kit are real skinny cheap looking wires, don't use them.
I used them originally and it fried my headlight switch on a long drive home one night.  The harnesses didn't hold up to the heat, they melted, and then shorted out taking out my headlight switch in the steering column.  Make sure you are using good quality harnesses.
