Headlights....well....they are GM - Exterior Forum
Friday, June 15, 2007 10:34 AM
We are a Chevy Family. I have two Cavs (2nd/3rd), My dad has a 03 cav, and my grandfather has an 03 sunfire. All the headlights suck except for my 2nd gen. Maybe its just because im used to my 92' but my 00's lights just arn't doing it for me.
So the Question is
Will new bulbs (like : http://cgi.ebay.com/ebaymotors/9007-00-04-Cavalier-Nokya-Arctic-White-Headlight-Bulbs_W0QQitemZ160125690176QQihZ006QQcategoryZ36476QQrdZ1QQcmdZViewItem ) help me at all? will i be able to see better? OR will I have to buy projectors for anything to change.
Thanks in advance
Re: Headlights....well....they are GM
Friday, June 15, 2007 11:38 AM
Go buy some silverstars. They are better quality
Friday, June 15, 2007 12:52 PM
I like Nokya because i have a pair of H11's and they are SO bright, because most bulbs are 50-55watts, and the Nokya is 80watts for the LO-BEAM! Silverstars are only 60watts i believe...
My CarDomain!!! --- http://www.cardomain.com/ride/2543660
Friday, June 15, 2007 1:40 PM
Lefix wrote:I like Nokya because i have a pair of H11's and they are SO bright, because most bulbs are 50-55watts, and the Nokya is 80watts for the LO-BEAM! Silverstars are only 60watts i believe...
Keep in mind that using such a high wattage in a 55watt rated harness could possibly melt the harness altogether and cause problems done the rode. My boy did it to his BMW with Noyka bulbs. He wised up and got HIDs though now.
Friday, June 15, 2007 1:45 PM
oh also silverstars are 55watts for the low beams. They are only brighter because they sit higher in the light spectrum. Silverstars = 4200K +/-, stocks are 3200 +/-. So they are brighter and "whiter" and lets not get into the K color discussion again, but since we are on the subject of lights, Halogens past 4300K are whiter but less bright. HIDs achieve a brighter light and color with the gas and lens filters that are used in the projectors. If you want bright halogens go Silverstars or PIAA Xtreme whites which I have. If you want brighter go with HID.
Friday, June 15, 2007 1:47 PM
edit ....
oh also silverstars are 55watts for the low beams. They are only brighter because they sit higher in the light spectrum. Silverstars = 4200K +/-, stocks are 3200 +/-. So they are brighter and "whiter" and lets not get into the K color discussion again, but since we are on the subject of lights, Halogens past 4300K are whiter but less bright. HIDs achieve a brighter light and color with the gas in the bulb and lens filters that are used in the projectors. If you want bright halogens go Silverstars or PIAA Xtreme whites which I have. If you want brighter go with HID.
Friday, June 15, 2007 1:56 PM
I have the Nokya bulbs in mine. They are NOT bright, but they give off a much whiter/blueish color. I also have a set of PIAA bulbs that I swap in before long highway trips. Much brighter but color isn't much different than stock.
From my experience if you want color go with Nokya bulbs, if you want more light output go with Silverstar or PIAAs, or if you want both color and more output go HID!
Friday, June 15, 2007 2:08 PM
I had Nokya bulbs in my 01 cavalier and it started to get the harness hot so I took them out of the car. I am gonna either get the harness upgrade or just put in HID's at some point.
Friday, June 15, 2007 2:12 PM
I have never had trouble with harnesses in any of my cars, and have used high wattage bulbs in all of them. I do plan to upgrade to HIDs in the near future tho.
Friday, June 15, 2007 2:52 PM
I have silverstars in mine, thats the second thing I did to the car, right after intake.
great lights, but im going for HID's soon
Thrice . wrote:i think you should go back and try to actually order some cam valves. see if he has any in stock. then ask him to give you an actual price and show you the website or anything legit about where he orders from...for all you know he is this dumb, and orders things that don't exist....he's probably got 10 of those ebay transistors that gave him eleventy hundred pony power....what a douche.
Friday, June 15, 2007 6:31 PM
9007's right?
Do stores carry them?
Friday, June 15, 2007 10:54 PM
9007's
Got mine from partsource
Walmart carrys them
Crappy tire carrys them
any 9007's will do, i was GOING to get some...ultra halogen silverstar thing...they wanted like 100 for them from partsource
anyhow, not hard to install at all, either.
make sure, if you get say...(APC 9007 ultra blues) (Just made that up...) for example... make sure it's street legal.
but yeah
silverstar, by Sylvania i think?
it has a light diagram on the back, to 'show' you what you're getting
Good Luck!
it DOES make a world of difference
Friday, June 15, 2007 10:56 PM
Mark, edit your car's so it's easier for people to see what you have. Location, too
Im not cure what SE CT means... (i'm canadian, so that's probably why lol)
Saturday, June 16, 2007 4:58 AM
Fixed it for you AJ
Thanks for the Help.
I'm bidding on a set on ebay right now. If i loose ill get them form Wally world.
Saturday, June 16, 2007 2:11 PM
just get sum HIDS and call it a day they help out alot when you wanna see more =D
5 seconds to find another street...
Sunday, June 17, 2007 4:50 AM
Im thinking i may need a clutch soon, so i don't have the cash on hand to drop on a HID kit.
Its a Future Plan if i dont drop the car at all.
Tuesday, June 19, 2007 6:21 PM
I thought I needed a clutch.
i didnt...i got the fluid replaces, as well as oil, and it works fine...
try that, first...check levels though, before getting new fluid, because they'll put new fluid in, if you get a new clutch.
good luck
Wednesday, June 27, 2007 11:39 AM
I have those bulbs in my 97 cav they look awesome at night and on rodes without any other lights that are outstanding but, this is my expierence only, on busy roads at night they don't do quite as much for me as say even the stock bulbs
