hi. i having the hardest time trying to find sum projectors for a 2002 cavalier. which i looked in ebay. so any help in pointing me in the right directions. Thanks
yeah go with IZNTRBL, or make ur own .
izntrbl
thanks. i have hid ready to install but not on stock headlamps.
no one makes stock HID projector headlamps for 2000 and up.
Must get someonet o fabricate and make one. like Izntrbl.
Believe me, I've tried.
I'm jsut reverting back to 95-99's.
Alrian Clitso wrote:thanks. i have hid ready to install but not on stock headlamps.
Well I hope it is not a 9007 bulb kit, cause they don't make any 9007 projectors at all that I know of for HID's. DS2's and H1's are about the most common used for a build. Just thought I would help you out. Also if you look around there are some things you can do to the 00-02 Stock Headlights to get a cutoff.
Just look up what Viper did to his. I'm not sure of the post's name.
dang. yea there 9007 sets. i wonder if its possible to cut into the harness and run a different set of bulb. im not familar with lights or HIDs.
It is not that you need to cut into the wires/harness. You would have to cut into the projector/bulb to fit together. You can spend another 75-100 bucks and contact the company you got the 9007 kit, and they can sell you a DS2 or H1 bulb for whatever projector you get. That is what I'm doing for my setup I'm doing cause I'm swapin' my 9006 kit off my white car for bulbs for my fogs on my Sedan. That way I have HID headlights and fogs.
I really hope that helps you.
i've been riding solo but i like to thanks the ppl for helping me with dis problem. ok i got hold of sum projector off a ford focus should be in the mail soon. lucky i know the guy before he sold the car with it. but its h3 projector low beam and h1 reflector high beam, there from a company called matrix.i was wondering if the wire can be modifled to the 9007??? sorry im clueless with lights plus on a tight college budget. and epoxy them on my headlights. by cutting out a hole to fit the lens or whatever in it. sorry for all the question. any thoughts helps. thanks.
