Anyone have problems like this? I have had to adjust the damn things a few times but now they are sagging, It is mainly the drivers side (and the shock is pretty much shot) so I though that was the problem but the pasanger side is doing it now. Anyone have any issues like this?
____________________________________
Primer Counts as Custom Paint Right?
BTW: This is my Sig.
most likely just the hinge sliding away from where it was originally mounted.
i noticed that when i had my old mms lambos
Yea makes sense. Bad part is it is messed up the latch on the door, you have to move it up everytime you close the door now.
You can feel it "slide up" when you close the door. sounds like @!#$ too. Hate these stupid things
well if u say the shock is shot. chances are that might be part of the problem. i had my passenger side shock completely blow out on me and it did what your talking about. also the adjusters work a bit until after several shuts then they kinda loosen up and makes the door go down. if that makes sense
I NEED a 97-99 LD9 engine harness for an auto.PM if u hav info.!!
Makes sense, the drivers side shick works when it is warm and you hold it up for a few mins lol the pass side shock is fine, I suppose I need to find some shocks for it now.
when its warm youll get more pressure out of the shock. when its cold the shock will seem like its about to give. your best bet would be to get a new set or 1 new shock before it blows completely and it causes more problems. email joe at modified-motorsports.com and tell him you need a new shock. he cut me a good deal when mine blew.
I will do that thanks!
no prob
