Ok don't say use the search button, cuz i already tried and didn't come up with much of anything...
So right to the point what is the BEST and easiest way to get the Len's off my 05 headlights??
Need help asap!
Thanks, Gary
Im guessing its similar to my 02 cav headlights which was the grey rubbery seal. If it is just get a utility knive and wedge it between the housing and lense the start sliding it around. My cav headlight took maybe 30 secs each to get them seprated.
same thing here just get a putty knife and go around the edge or if you wanted to you could put them in the oven to heat up the sealant but might risk melting the housing
hey the best way was to dremel all the way around it. I tried baking it in the oven but that didnt do anything but make the plastic easier to break around the edges
if u dremel it all around ide suggest getting black sealent. i havnt had any problems with mine and no moisture on the inside
search for a post i made about angel eyes in stock lenses......i baked it and still had to break off pieces of the housing but even izn trbl says its really hard to do so meh.
Thanks guys!... I ended up cuttin along the edge with a zip wheel
