Drivers Side Headlights DIM all the time. - Exterior Forum
Sunday, December 09, 2007 12:53 PM
Hey guys,
I have a 96 Cavalier. The DRL dummy light was flashing for the longest time. Put new bulbs in, didn't solve it. Didn't care and still really don't care about the DRL working or not, HOWEVER, the Drivers side lights high and low beams are both dim. I used my MultiMeter to measure the voltage on the pins for both High and Low on both sides drivers and passengers. The one side is reading the proper 12+V, that's the one that's working fine, and the side that's dim is only around 6 to 7+V ... Which makes sense why the lights are half as bright.
Does anyone know what's happening here ? I'm almost ready to do the jumper thing in the relay to see if that will fix the DRL and possibly fix the dimmed light.
Thanks for reading, hopefully someone has a solution.
Tom
Ontario Tuners Organization Administrator
http://www.ontariotuners.org - Ontario Tuners Org
http://www.cardomain.com/id/sfuse98gt - My Car Domain
http://www.ontariofires.com - Ontario Fires
Re: Drivers Side Headlights DIM all the time.
Sunday, December 09, 2007 1:02 PM
Did u check the fuse?
Sunday, December 09, 2007 1:11 PM
Ya, fuse is fine, not blown. If the fuse was blown they wouldn't work at all.
How much are the DRL modules located near the radiator for the lights worth ? Anyone know ?
Tom
Sunday, December 09, 2007 1:23 PM
had the same prob with my 98 z24.it's the drivers side headlight fuse. the drl will still work but the headlight won't.wich makes it seem always dim.it also makes the light on the dash flash.seriouslt it's the fuse.i jave heard of a bad ground under the battery box causing the same problem though
oops sorry for my bad grammar
Sunday, December 09, 2007 1:59 PM
trevor mullins wrote:had the same prob with my 98 z24.it's the drivers side headlight fuse. the drl will still work but the headlight won't.wich makes it seem always dim.it also makes the light on the dash flash.seriouslt it's the fuse.i jave heard of a bad ground under the battery box causing the same problem though
Well, the 15 A fuse for each side light are both fine, they're not blown. So unless there's some other fuse then.
When i turn my highbeams on, the drivers side never changes, all 4 lights remain on, however the working one now has a bright and low, and then they swap. To me that's a relay problem.
Tom
Sunday, December 09, 2007 3:12 PM
under the bat box there is a ground on the frame runing from the loom.start there and work from there.thats what someone told me when i did it .i checked the fuses first and lucked out though.try that anyway.the guy who told me that had fixed a few with the same problem as u described already
