I was wondering what is all needed to put factory fogs in a non fog 01 cav? What is neeed and what needs to be done.....thank u all.
95 Neon MTX 2dr- 2.4 engine, more to come...
01 Cavalier 2dr- 2.2, GF's car, full pioneer system......still needs mods.
ok found this diagram....seems straight forward...but one thing im stuck on is the relay...what relay is that? And also do i really need the wire comming off the 84 post to a switch and light indicator?
ok let me restate this.... i dont get the relay, read up a lil and found out that i can wire the 85 wire to the brown wire the fron signals have so they come on with ligts. MY QUESTIONS ARE!!!!!
Wich relay is that?
And if its one i need to buy what kind is it?
if your not familiar with wiring, please don't attempt to be.
the bosch relay is common and if you go to a parts store and ask for a five prong relay,
make sure the five numbers coming off that relay are the same as the picture diagram. 30, 85, 87, 87a, and 86.
*MSR 190 wheels not shown in sig.
http://www.myspace.com/fpsunfire
5 seconds to find another street...
the problem you will face is that you cannot put in "stock" foglights in the stock location. the bumpers are two different bumpers - those fog surrounds are not interchangeable - they are part of the bumper. the bumper plastic is all one piece all the way around. if you want the STOCK ones, you're gonna have to switch out bumpers.
exactly wut i was gonna do bud.....ok so i need a 3 prong relay with the numbers as shown...sould be a snap i wired fogs before in my old car but it had a switch so im new to the relay method...looks straight forward.....only 1 more question.
Where do i put the relay? In the fuse box under the hoo(will have to be wired in)
OR
Do i just use connector and connect the ends to the relay with them and tape it all up and mount it sumwhere on the frame.
How did YOU do it?
Hows this one.....
http://cgi.ebay.ca/12V-12-VOLT-30-40A-SPDT-RELAY-w-SOCKET-WIRE-HARNESS_W0QQitemZ220184063939QQihZ012QQcategoryZ50459QQssPageNameZWDVWQQrdZ1QQcmdZViewItem#ebayphotohosting
Ok yes, that is the relay you need.
No, you do not need to wire it in to the fuse box. Put it where every you like. Most have a bracket on then, mount it to your firewall. Doesnt matter where you put it.
Make sure you put an inline fuse in the line coming off the battery.
Follow that diagram you found to a T and you will have working fog-lights.
Dont wire them in with your parking lights, Just put them on a switch.
Its not that hard to flip a switch when you want your fog lights on. You said you wanted factory fogs, factory has a switch.
And no need to order a relay off ebay. Goto Autozone, Napa wherever they will have the same thing for the same price.
sounds great man ill do just that! thnxs everyone!
can you not just wire it exactly as it would be in an OEM application? like get the dimmer with the fog switch and just kinda add the wire to the harness? you'd think there'd already be provisions in the harness for that like the clusters have..
maybe i'm wrong but that makes sense to me..
www.driftnamiperformance.com
