Just picked up a VIS OEM carbon fiber hood (used for i think 4 years)
my qustion is do I HAVE to use hood pin?, there were no hood pins in it so i figure if its been good for 4 years then it still should be.
I have one true love in my life...And my girlfriend sits next to me in it
does it have mounts to put the oem hood latch if so then no pins thats prob the way he had it
no there no latch or anything... i have to transfer the one from my stock hood.
I had them on my car because the airflow lifted up the inner headlight corners of the hood. Doesn't help that I have the two vents right in the middle of the bumper. Most Cavs that I've seen with CF hoods don't use pins because they don't have that problem.
no, you dont
have to use hood pins. most companies list them as "needing" hood pins simply as a way limit their own liability. but accidents do happen because there is a lot of pick up caused by the air flowing under the gap in the cav hood/bumper. so its up to you on what to do. the chances are that you will be fine. but if you run without them dont complain if your hood flies up and busts your windshield or makes you wreck. i know a few people that that has happened to and i know tons more that have been fine w/o em. so it just comes down to what you want to do.
coming back in 2008...
Boorad wrote:no there no latch or anything... i have to transfer the one from my stock hood.
ok do so and should be fine like stated most companys state that for liability reasons in the RARE occasion it does happen.
thanks guys.
well i dont expect any fines. its painted to match the car to it doesnt look any different then a stock hood
i just picked up a c/f hood and was wondering the samething, thanks everyone and sorry to thead jack u boorad
my car never see's speeds above 60KM/H so i think ill be fine...
i who have nothing but the comfort of my sins...
fines? you're not going to get fines for having a carbon fiber hood without pins.
the good thing about the VIS hoods is they do not retain the stock 'hole' underneath the catch latch that bolts to the hood. With a VIS, its completely solid right there. ive seen other cf hood manufacturers that have bored that hole there though...
the problem usually lies with the bolts being ripped out of there threads in the hood, but really is not a MAJOR issue on our cars.
take mine for instance, VIS oem style, ive had it on the car for 2 summers and the car saw a few 125mph stints and the hood was fine.
z yaaaa wrote:the good thing about the VIS hoods is they do not retain the stock 'hole' underneath the catch latch that bolts to the hood.
the companies that utilize this feature usually do so as a drainage point for moisture or any water that gets trapped between the outside (top) layer and the frame (bottom) itself. generally, the top is carbon and the frame is glass.
the thing i like about VIS is that usually the bottom also has a carbon layer on top, giving the appearance of a fully carbon hood (even though no production hoods for the cavs are fully carbon)
Its just a safety feature for you. If you don't plan on going too fast than you really don't need it. I put them on my car because like the other guy, mine was lifting at the bolts/hinge. It is recommended that if you ever go past 100 or hit anything close to that to put hood pins on. I had a friend who didn't have them on and at the strip his hood flew up and blew up it looked like haha, well, it just flew up cracked windshield and sunroof and the hood split in 5 pieces.
