so here is my issue ATM. I am wondering if you can take apart tail lights the same as you do headlights. Got an idea for LEDs
      Also if anyone can find me the post on the headlight how to would be greatly appreciate it
 ( because if you can do it the same I will need the temp and time )
Thank You
5 seconds to find another street...
yes yu can  heat gun slowly  pull apart
a lot of people say it rarely works. people have had good luck with smashing the back on one set and the front on another. then jsut glue the two together
what u mean?
thanks kardain so how did the lights come out after 2 years later? =D
Im at work so I cant see pics at all so ya have to wait till 4-5 to see em
Thanks again!
What I wanted to do with my tails was remove the lense and keep the housing and then I have a set of TYC tails that have the clear plastic lense that i want to pop onto the stock ones so you can see the LED's alot better...
The when I mess with the TYC ones I am not positive how I will need to get them apart
you can buy the clear lenses from IZN
haha
StreetWhite03 wrote:thanks kardain so how did the lights come out after 2 years later? =D
Put to the back burner (no pun intended) while I'm working on the engine swap.
BoltZ DesignZ wrote:yellow22 wrote:you can buy the clear lenses from IZN
and hope and pray you get them in a reasonable time...
i didnt know he had that rep with shiping my bad lol
So if I get this right I can take the set of TYC tails and just sumhow get the housing seperated from the lense and then just smash the stock red lense I should be safe
and by chance do you know IZNs site?
my fire is an 03 and from what i have seen on the site no 03+ clear lenses
