lookin for some sweet Led taillights... ive searched all over the internet but all i can find are stupid altezzas and cf/black tails...
help me! - 00-02 style
dang... that sucks for me... lol
how would i go about doing that?
get the outter housings
cut a bracket and drill some holes
fit the LED's and wire them together in line?
im not to much of a genius electrician, so if i get a basic idea, ill probably end up having my friend help me along. i love LED"s and im tired of getting pulled over for braklights out
i have also heard that if i were to run LED"s usually it throws a "your bulbs are burned out light" on the dash, how would i be able to avoid this? some sort of capacitor or another source to draw from?
you'd need a grote flasher
flasher
load resistors get hot and are only a band-aid. this flasher (whic is the same price as our stock flasher) is a true answer.
brilliant! (but for the simple mind like me) where does it go? lol
If I am correct it goes in a relay were your fuses are... looks like the same one for the DRL's
5 seconds to find another street...
no. its the actual flasher. it goes under the dash. easiest way to find it, turn on your hazards or turn signals, and find the clicking.
alright thanks! ill be looking into this over the summer!
If you use LED bulbs, as described above, it'll take just as long as replacing your taillight bulbs and a light flasher to do the conversion. I've done it on mine, and it looks fine and works well.
I'm considering a full LED panel behind my tails next...that's quite a bit more involved, and requires a lot more hardware to pull off. It's not something I'd recommend for the non-electrically inclined, but your taillights end up resembling what you see on a Cadillac when you're finished...one complete light panel with no "hot spots." It's definitely unique around here, though, and that's what I'm looking for.
im looking for the same thing.. i have a mock up i made for just a general idea, ill post that whenever i upload it, its just a quick thought i had and put on MS paint.
quick idea of my thoughts.
probably going to move the reverse lights to the bottom instead of the middle.
