yes i used the search button first but couldnt find anything but i've heard 2 diff ways to put on side skirts one is you screw into the door sills and ive also heard that you use double sided tape which is the best way to do it and can someone post up a pic of how the front bumper mounts one from the front and one from under the hood? when i got the car there was no bumper support bumper that was on there was zip stripped lol so id like to see how its spose to be thank you
"how do you get in"
A lot of people use double sided tape...I personally would not...tape does loose it's strength in some cases and could result in a side skirt bouncing down the highway.
Screwing in the skirt works just fine...in addition to the door sills I would also sink a screw or two in each wheel well where the skirt lays in it.
If you want something a little more permanent and much stronger, I use a 2 part epoxy from 3M called Speedgrip...they make one formulated specifically for fiberglass/urethane - metal bonds. Run a bead of that along the door sills and around any part of the skirt that actually touches the car, clamp it for about 20 minutes and it'll be as tough as a weld. You can get a tube at most auto body supply places for about $25...when it comes time to take off those sides 3M also as a chemical product that will dissolve most of the epoxy so you can pull off the skirts without damaging them.
As for the bumper, what year is it? My '04 (and most other years I believe) will use the two bolts in the bottom of each fender to attach the sides of the bumper...my evo5 bumper had to way to bolt it to the supports on the inner side of each headlight so I just fabricated some small metal brackets that I could glass into the bumper then bolt the other side to the car...if you can post any pics of exactly where you problem are is we can all probably help you a lot better
Hear are some pictures of the bracket that holds the bumper on
you need to take your headlights and blinkers off
do the screws on the door sill/rivets, and double side tape on the body
hop on in i've got a J
its a 98 the car had been in an accident in the front before i dont even kno if that bracket is there cause when i got it i changed out the lights for one piece projectors and the turn light just kinda fell out ill look tommarow and take a couple pics
"how do you get in"
yup guys i got it all figured out and on rite i think lol i just am pre fitting them but it looks good now just sides and rear any pointers for doing rear bumper?
"how do you get in"
L brackets in the rear to hold the middle up.. or else it'll sag like a mofo in most cases
www.driftnamiperformance.com
i got the blitz body kit and thanks so use tape on sides not screws? just screws in wheel wells
"how do you get in"
jere k wrote:i got the blitz body kit and thanks so use tape on sides not screws? just screws in wheel wells
The screws on mine have pulled the fiberglass. I've backed them off as much as possible before hitting the bottom of the door but I've still got a slight pool around each of the two screws.
So, I'm gonna go with tape when I repaint 'em.
ok nevermind i guess i went to put my skirts on and there like an inch to short any one else had this problem the front bumper went rite on wasnt off a bit now the skirts are to short what do i do? take it to a body shop and have them cut it and refiberglass it?
"how do you get in"
Call the company.
Tell them it's clearly an inch to short, that you expect a replacement, and if they want the old ones back, it'll be at their own cost.
If they say no, well I'm hoping you ordered the kit with a CC, because then all you have to do is explain your situation to your CC company, and have them charge it back.
2002 Sunfire -->
- Ractive steering wheel
- ASA 17" EM9 + Nexen N5000 215/45/17 (steelies for winter)
- D-Spec Lowering kit @ 1.4" (issues currently
- Rockford P250.1 + MTX MZS1004 + Panasonic CQ-C8313U head unit
- Barely legal tint.
yeah i ordered it with a cc and yeah i rly do like the skirts i called the company and they said that they have to be shaved down on either side
"how do you get in"
