Im looking for projectors for a 03-05 cav headlights.
I stoped on izntrbl.com and noticed that he uses '06 Infiniti FX35 Bi-xenon projectors, now is their other ones I can use that will do the same job as those or those the only ones that you can retro fit
any help would be nice thank you.
5 seconds to find another street...
anyone?
no one else sells them they build them like i did. heres the link
http://www.j-body.org/forums/read.php?f=7&i=354536&t=354515#354536
oh yeah i got a set of projectors for sale $40. 2 bosch H3 12volt bifocal projector lense housings with lenses.
also just so you dont ask later here how to do halos all you need is clear high temp tubing 1/4 or 1/2, 4 leds your choice of color. and clear flat beads. fill tubing with the flat beads, wrap tubing around a cylinder and heat with a heat gun and let cool. insert an led into each side of the tubing and seal with silicone. and wire up with proper resistors and diodes. repeat for other side.
awesome thanks for the tip umm those projectors you have for sale are the same kind you used? I just want to make sure that the 9007 hid bulbs work/fit...
how have your been doing? since you have posted about it... holding up well still?
no the pair i have for sale are smaller in diameter with a bifocal lense and they come with a h3 bulb
Casper wrote:awesome thanks for the tip umm those projectors you have for sale are the same kind you used? I just want to make sure that the 9007 hid bulbs work/fit...
good luck finding 9007 projectors. the fx35 use d2s
so my best bet is to get teh fx35?
