anyone know of some tail replacement bulbs that are thinner/slimmer than the norm?
or if another bulb # fits in our stock tail harnesses?
I use the LED bulbs that you can buy at pepboys etc...
They are slim then at the top they are circleular with about 10 leds in them.
tho they make the flasher blink faster I dont mind it. Love em to be honest with you.
5 seconds to find another street...
but at the top where the LED's are....is it smaller in circumference than the stock bulbs? or bout the same? I would have to assume same
these are the exact LEDs i used and are WAAAAY brighter than the ones that they have at the local parts stores! they are just a little bigger thant he stock size but give off great light and fill the whole lens instead of just having the focused LEDs spot on the tail light
NICE LEDs
simple minds talk about other people.
average minds talk about events.
great minds discuss ideas
not looking for brighter....looking for slimmer
to fit a smaller diameter hole
what in the blue hell are you up to Joey?
and from what ive seen there is another bulb that will work and is slightly smaller i just cant remember what number it is. When I get home I'll look around see if i still have them.
SATCH PROGRESS THREAD!!!
There ARE other bulbs that plug into our harness, but they are all relatively the same diameter bulb.
If you want to go thinner, you have to find the (most likely dual filament) bulb you want to use, and get a pigtail for that bulb...then just splice them in.
ya I found a spare led bulb and it has 12 L.E.D.s in it. but it focuses the beam so when it lights up on the tail light its a perfect circle the 9 L.E.D.s around th outside are lit when the lights are on and the 3 inner ones looks like a triangle are for the turning hazard.. but when breaking all light it. Thats why i wanted to find clear 03+ fire lenses to make the rear of the car more appealing....
this is what they look like
did you read my last reply? im NOT looking for LED's.
JtotheOtotheEtotheY wrote:did you read my last reply? im NOT looking for LED's.
Maybe you should be. There are tons of different designs, and some could be thinner.
Shop Manuals, Brochures:
www.kenmcgeeautobooks.com
