I have a 04 sunfire and i want to get projector headlmaps or make my own. Where can you buy the parts ? My other question was that i noticed some other GM cars like the G6 have fog lamps that look like projector lenses, would that work for a headlamp projector ? Please let me know.
most will send you to izn
5 seconds to find another street...
I've been looking for about 2 months now, and no luck (not going to deal with izn). I'm pretty much going to build my own. I was thinking the same thing for the projector fog lenses, as I had just picked up a set to replace my stock fog lights. I will try to work on them this weekend and see how it goes.
great idea using projector foglites i hope it turns out well
if either of you are interested i have 2 pair of projectors for sale at $40 a pair pm me if either of you are interested
pm sent
did you use a dremel to cut the headlights? I'm still trying to map this all out before I actually do it haha. I will praise you if you do a How To
I found a different How-To with the same concept here:
Converting Reflective Headlights to Projectors
i used a dremel cutting wheel and sanding drum on mine
im in the process right now. im not doing HID's, just projectors. the turn signal projectors are passat fog lights, the main projectors are passat headlight projectors. the turns are mounted right now. im still experiementing with the main one as you can see the black plastic behind it. im still deciding what i want to do with it is all. lots of options. oh and aiming them is a bitch. im having a problem doing it right now. sorry for such big pictures, my resize program is not working.
