Ok so im in the midst of doing the swap from 9005/9006 bulbs to 9007 bulbs. I took the headlight harness out of a 97 sunfire gt and plugged it in my cav. Everything works good although the brights do not work. Any one have a solution to this? Thanks in advance
ah, heehee. that just might have made my week. i think what Stephen is trying to say is you didn't even try to research this. wanna know how i know? cuz there's a friggin sticky on this very subject for god's sake. now go out there and get 'em, high speed..... good luck!
Ok first off, if I didnt look this up then how would I know that this swap is possible? I asked a simple question and people assume that I havent searched. I have everything working just the brights wont come on, if your not going to answer my question or at least help me, then dont post.
You did not say anything that you did beside swapped harnesses. What connection did you make? Im guessing you missed a ground or there is a fuse blown,
Thats all i did... Just swapped harnesses and connected the ground... Everything is working but the brights.
There is a fuse for the brights I believe inside the car check that out.
Checked all the fuses inside the car, nothing is blown. UH. I thought this was gonna be pretty much straight forward, guess I thought wrong. lol
