Do the 95-99 taillights fit on a 00-02 and if not is there any way to make them fit cause i have a set of aftermarket tails that i bought off of ebay and they were llisted to fit 95-02 and when i tried to install them they just didnt seem to fit i just messed with them for a few minutes didnt work with them long i can send them back if i need to just wondering if there is anything i can do before i send them back any help would be appreciated
left goes on the left side, right goes on the right side.
WiGM-Tuners member.
First of all learn to use some punctuation. 95-02 tails are interchangable so they should work. Pics of the tails you ordered?
I put 95 tails in my 05
z28guy(KGM BEOTCH)
I know how to install the taillights and I guess I worded it wrong. They fit but there is a bout a 1/8 to ¼ inch gap at the top of the taillight and I only had enough time to try installing one of the outers and it didn’t look right with the gap at the top.
You have to take the rubber molding off your stock outers and put them on the new ones most likely.
95-05 will work.
Fall 08 Omaha/western Iowa area meet...
CLICK ME!
Problem solved i transfered both rubber moldings from stock to the new ones and they fit fine thanks for the help
Member of JBO - 9 Years & Counting...
Is the dealer the only place to get that rubber molding outside of the junkyard? On my tails that rubber is starting to crack and its just an eyesore.
your new ones from ebay should of came with them. and if not try autozone or just go to lowes and buy some 1/8 rubber and glue it to your tails.
is this only true with cavs or are all cav and sunfire tails from 95-05 compatible? id like to get some different ones in my 97 and paint the center piece thanks guys!!
98regalgs wrote:is this only true with cavs or are all cav and sunfire tails from 95-05 compatible? id like to get some different ones in my 97 and paint the center piece thanks guys!!
Sunfire Sedan Tails will interchange with Cavalier Tails. Sunfire Coupes you're SOL.
SO EVERYTHING!
You will have to cut and weld, it's very time consuming and hard if you are inexperienced...Just take your time...
