quick trunk question - Exterior Forum
Saturday, October 11, 2008 6:00 PM
Im thinking about shavin the inner tails on my cavy over the winter. my ? is what is the best way to do this I do have some body skills. just wondering what some of you have done and if you liked the turn out thanks guys
http://www.j-body.org/members/image/whyte01cavy/personal_pic.jpg/
Re: quick trunk question
Sunday, October 12, 2008 2:31 AM
Welding is the proper way. If you fiberglass it and/or bondo it, it will crack and look like @!#$.
Sunday, October 12, 2008 4:58 AM
Bagged Base Coupe (Tinkles) wrote:Welding is the proper way. If you fiberglass it and/or bondo it, it will crack and look like @!#$.
i second that do it right the first time you won`t regret it
Sunday, October 12, 2008 8:56 AM
to add to this... you cannot fill the entire area in with filler or it will crack.
after welding your going to need to use a skim coat of filler just to get it perfectly smooth. but you sand most of it off so it wont be an issue.
In the end, we're all just chalk lines on the concrete.. drawn only to be washed away.
Sunday, October 12, 2008 5:35 PM
and to add to all the above...
to make sure you have a good finished product, once you have your skim coat of filler on (and it may take more than one depending on how clean/even you welds are)...block sand the trunk as opposed to using a DA or orbital. It will help make sure you get a nice even surface with no low spots or waves...remember, if you have any defect at all in the body work, the paint is going to amplify that ten-fold.
Monday, October 13, 2008 9:21 AM
tru dat....all dat....
Monday, October 13, 2008 9:39 AM
fiberglass and bondo the whole thing. it will look great for 2 weeks
Monday, October 13, 2008 1:09 PM
weld it up, just like every one said. im on my second shaved trunk and currently working on another. use tons of small tach welds to hold the plates in place at first with out warping the welding area. then use single passes between the tachs, to make seam welds. that will give you the most durability. most imp. of all TAKE YOUR TIME!!!!1!!1! its not a race. the smallest imprefection will ruin your trunk, use as little filler as possible. remember most sandable primer is buildable, and that can be utilized, just watch for heavy spots theyll crack
just some things to think about
Monday, October 13, 2008 1:17 PM
hey i met you at nopi at milan, i had the black sunfire that won 2nd and my buddy dan's cavi won 1st remember? if you want some help i live in berkley, mi .
248-909-6765
jason
Monday, October 13, 2008 7:29 PM
thanks guys for all the great tips I ran into a few other problem s since postin this, so the trunk will be on hold for a while. I might do in the spring before I get it painted we will see but again thanks.
