what all year of door will fit on a 2000?
i need a new door and was thinking i could run to the junkyard and steal one off a 95-99?
95-05 all the same. doorpanel might be different but thats easy to switch over if it is. the door itself is all the same though.
Did I mention I drive a 2000 Lumina now?-----wigm-tuners.org member
just grab the whole door from a 95-05 .... if you can get %100 percent of the door... get it... straight bolt on.
sweet thanks guys. was pretty sure it was. just wanted some comfirmation.
hes better of getting one from a cavalier ... unless he finds a sunfire door without the door skins.. as the fire doors will have holes once the the skins are removed. sunfire door skins or stikers are not glued on like cavies..
AZ24Ncav wrote:hes better of getting one from a cavalier ... unless he finds a sunfire door without the door skins.. as the fire doors will have holes once the the skins are removed. sunfire door skins or stikers are not glued on like cavies..
yes i dont want a fire door because of the moldings and the inside plastics dont match up with the dash, and if i'm getting a full door might as well get on that matches as close as possible.
obviously it must be a coupe door but like others have said any door from a cav to a fire will work.
do you need a passanger or drivers door?
____________________________________
Primer Counts as Custom Paint Right?
BTW: This is my Sig.
mine were all glued on from the factory...no holes. (4 door sunfire)
974drfire (Matt Littel) wrote:AZ24Ncav wrote:hes better of getting one from a cavalier ... unless he finds a sunfire door without the door skins.. as the fire doors will have holes once the the skins are removed. sunfire door skins or stikers are not glued on like cavies..
sedans are more like cavalier coupes and sedans... sunfire coupes on the other hand, have holes
thats what i was thinking... my driver side fender was replaced recently and it has holes for the side molding because it came from a GT.
