okay I have a 96 cavalier!! And there is a funny smell like something is burning comin from all four BRAKES i'm guessing something from the wheel anyways!!!! And the reason i figure its the brakes is cause the ABS light is on!!!!! It has been raining here alot if that could help with any thing but anyways any help would be nice and very much appreciated!!!!!!!!!!!!!! Thanks!!!!
L!L C@VI
this might be better off in the maintenence forum...
Did I mention I drive a 2000 Lumina now?-----wigm-tuners.org member
Does it feel like the brakes are dragging? Do you have any noises that appeared (or rather became audible) when the problem came up? The ABS system uses a pump and valves to control/modulate pressure to the brakes. I can envision a situation where the pressure might not be releasing properly, causing brake drag. This is serious and should be looked at by a knowledgable person asap.
