hey guys just bought a 99 2dr z24 on the cluster it shows the right turn signal lit up all the time when lights are on whats that all about??
and i put in a bulb and it was really dim then 10 min later it went bright and bumper bulb blew
main ? how come the signal light is always lit up on spedometer its just solid green
Usually, this means you have a bulb out. Since it appears you have tried this, and the bulb lit dim, I'd say it's a bad ground somewhere, bad multifunction switch, or bad flasher.
Did I mention I drive a 2000 Lumina now?-----wigm-tuners.org member
I would think bad ground or short somehere, mine was just totaled and i noticed the wiring harness damaged and doing the exact same thing when my light switch is on.
