I picked up a set of toyota cavalier tail lights and after reading 3 or 4 different write ups on how to install them, I still can't figure it out.
Is there a harness that comes with the toyo tails that I'm missing?  This is what I got from factory housing:
I went out and bought a bulb socket since none came with the lights I got, this is what I have:
I can't seem to find the four wire harness with the white wire as pictured here anywhere:
So my questions are:
Am I missing a bulb socket that comes with the toyo tails?
Where is the white wire that I need coming out of the harness?
Thanks
Danny
2004 Sunburst Orange Cavalier
check it out here @ www.cardomain.com/id/orange04cavy
and im trying to wire them into a 1996 Z24 if it makes a difference
Danny
you need the harness they come with.
Do you know where I can buy the harness from?  Gm sell it?
Danny
gonna be like a needle in a hay stack. no actually you have a better chance at find the needle.. lol    good luck, i have no idea where you can find those since they are part of a lighting harness in the toyo cav.
talk to manta, maybe he can make a harness for you since he just made a plug and play harness for his tails, you MIGHT get lucky. MIGHT.
i hate to bump an ancient thread, but I've run into this same problem and would hate to have a useless set of tailights.  Does anyone have an alternate way to wire these up?  Any help would be great.
Pretty sure I still have the Toyota Tail Harnesses. I might even have two sets. Just gotta dig through a couple boxes in the garage. Whats it worth to ya? lol.
SO EVERYTHING!
BoltZ DesignZ, you got a PM
If you need any other ideas, I can give ya some with how I did mine which is similar to manta's.
"United by Individuality"
"If life is a joke, why aren't we laughing?"
"Normality depends on one's perception of reality."
http://www.cardomain.com/ride/3820803
I'm up for anything, I'd hate to have a useless set of tailights.
Nobody?  Anyone?  I'm up for any ideas.
Anybody remember how manta did his?  Come on guys, help a fellow J'er out.
I can check a workaround this weekend...
That would be great, any help is appreciated.  Maybe all of this will help others as well.
Give me about an hour and I'll have pics up for you.
Okay finally got some pics of my set up.
First off is a pic of where I get my brake signal.
Since my LSS has a spoiler, I used the unused connector for the rear dash 3rd for the brake signal.
Now a shot of how my setup looks all hooked up.
A shot of my adapter/jumper harness.
All of the connectors and terminals I got online through two sites and with shipping cost about $27.
As for the pinout of the tail light side, the four cavity:
A: Turn Signal
B: Tail Light
C: Brake Light
D: Ground
Hope this helps you out and if you need part numbers for the connectors, let me know.
That helps a lot and yeah, part numbers for the connectors would be great.  Thanks so much for your help.
All part numbers are from Delphi
P/N's[Number - description (quantity):
12129490 - Metri-280 Connector 3M (2)
12129492 - Secondary Lock (2)
12129136 - Metri-280 Connector 4F (2)
12129138 - Secondary Lock (2)
12020116 - Male 280 Series Tin Terminal (6)
12110842 - Female 280 Series Tin Terminal (8)
08911773 - Pack-con 1 connector (1)
06294511 - Pack-con 1 terminal tin (1)
Everything except the Pack-con I had gotten from Mouser Electronics.  And I had recently checked for everything, and you can get it all from Mouser.  As a word of advice, do a search with the part numbers and select the listing with "New At Mouser" under "Mfr. Part #"  It will allow you to order units in multiples of 1, except for number 12110842 and 06294511.
Mouser Electronics
