would a 95-98 z24 front bumper be a direct fit on a 00-02 z24?? - Exterior Forum
Friday, October 04, 2013 10:48 AM
I have a 2002 z24 2.4l 5 speed and am not a fan of the front bumper and am missing the front "lip". Id like to swap it out for a 95-98 z24 bumper... would it be a direct fit with existing mounting holes?? And/or would i have to change the headlights and hood as well for it all to fit together and line up properly??
Re: would a 95-98 z24 front bumper be a direct fit on a 00-02 z24??
Friday, October 04, 2013 11:23 AM
You will need to also change your fenders...or mod your fender brackets, and your headlights / corner lights. 95-02 hoods are the same on cavaliers.
Friday, October 04, 2013 11:33 AM
Is it a major mod or something an average joe can do?
Tuesday, October 08, 2013 4:40 PM
Trying to mod the fenders is probably a waste of time, just buy new fenders.
The only "mod" you'll need to do then is the headlight wiring harness. Your 00-02 headlights use a single 9007 bulb whereas the 95-99 uses a 9006 low beam and 9005 high. You should be able to buy the connectors you need from your local auto parts store, or your favorite online seller (eBay, Amazon, etc).
Wednesday, November 06, 2013 2:46 PM
-MD- Enforcer wrote:You will need to also change your fenders...or mod your fender brackets, and your headlights / corner lights. 95-02 hoods are the same on cavaliers.
Sorry, not trying to thread jack but I'm working on swapping the front bumper from my 00 ls to a 97 Z24. I have new headlights for the 97 set up. Can I get around swapping the fenders by modding the bracket for the headlights? The reason I'm asking is because the driver side fender on the 97 is jacked up and would need some work to get it looking good.
