resin evil eye hood anyone ? - Exterior Forum
Sunday, January 19, 2014 5:25 PM
Anyone has done evil eye hood mod with resin fiberglass? i welded mine but the rust caught from under and now shows on top.
www.funnybikeshow.com
Re: resin evil eye hood anyone ?
Tuesday, January 21, 2014 11:56 AM
Only if the hood is glass.
Rule of thumb, if the hood is metal, weld on metal. If the hood is fiberglass/carbon, use fiberglass. If you try and put fiberglass on the metal hood, it'll eventually lift and peel off due to the different expansion rates of the two different materials.
Did you reseal both sides of the work area after welding them in (I.e. epoxy primer or another quality sealer)? If not, that's probably why its starting to rust.
Tuesday, January 21, 2014 3:30 PM
I did prime it after .
Tuesday, January 21, 2014 4:09 PM
Epoxy primer FTW!!!!
Tuesday, January 21, 2014 4:47 PM
No just primer then paint.
I guess i have to remove the hood and remove all rust under and on top then redo my fiberglass -bondo.
I have an extra hood and wanted to try doing evil eyes with just resin -fiberglass.
Tuesday, January 21, 2014 5:39 PM
Not gonna work. The fiberglass is only gonna stick for so long til it lifts.
And as Rob said, epoxy primer is the way to go. When you grind down to bare metal, you are removing the zinc coat applied from factory and that is what really seals the metal from the bottom up. Epoxy primer will properly seal the panel.
When I go to bare metal, I abrade the metal with a rough grit, shoot epoxy primer (especially crucial after welding something like evil eyes since the welds will probably rust out first if its steel filler), body work over the epoxy, then some 2k primer over the body work, then paint.
No good sealer over the metal, it'll rust. Unfortunately no way around it.
Tuesday, January 21, 2014 5:49 PM
Thanks for your replies guys now i'll get to work the right way.
Tuesday, January 21, 2014 8:41 PM
No problem
