88 sunbird turbo - Page 2 - First Generation Forum
Re: 88 sunbird turbo
Sunday, March 25, 2007 7:16 PM
ok I have an aftermarket temp guage so that would explain that
and had my charging system checked its charging a 14 volts so Im going to replace the ALT
as far as the knock sensor how would I check for an open ground
and the MAP may have to be replaced cause Ive changed all the vaccum lines because it sat for 5 yrs
thanks for the help Sharky any more advice for this car its an 88 Grand Am turbo
Sunday, April 01, 2007 6:56 AM
how do you check for a short to ground
<a href="http://photobucket.com" target="_blank"><img src="http://i3.photobucket.com/albums/y89/acbigshow/dopeyoffthelinecustoms1.jpg" border="0" alt="Photo Sharing and Video Hosting at Photobucket"></a>
Sunday, April 01, 2007 8:17 AM
One way is to disconnect everything which shares the wire you want to test. Use a DVOM and measure the resistance between the wire and the engine block (ground). There should be no connection, infinite resistance. If you get a number around .2 then you likely have a short to ground.
-->Slow
Sunday, April 01, 2007 2:40 PM
ok thanks.
