Well thanks to alot of contributions of opinion, I will be sticking with replacing the spark plugs with the OE ACDelco plugs.    As for the rest....  I will probably go for that engine restore stuff to see if it actually does anything, unless somebody knows an example of it causing engine damage, in which case I will write it off with the other spark plugs.  In addition to the restore, I think I'm going to use Valvoline SynPower 10W-30  oil.   At some point I'm probably going to throw a K&N Panel filter in for the sake of convenience, with maybe some glimmer of hope for an extra Horsepower or two.  Next, going to run part of a can of seafoam through the vacuum lines and through the gas tank to clean it out.  If anybody has suggestions/comments/concerns please tell me. I realize I may not be the most agreeable person, but I know I probably know alot less about these engines than most of you so...    Thanks.  (Also I was just informed a couple hours ago the water pump on the car went for the third time. So at least I'll have a new water pump and Transmission)
u can pick up a short ram or cold air intake off ebay for just a little bit more than that k+n drop in.
Yeah but those don't come with a K&N and I have not seen one for the 2.2. They are alll for the 2.4
No sorry, they are for the 2.2. But they are all for 1998 or newer.  I assume they will still work though
I was recommended by the Advance I called to check for parts that I replace the Wireset too.  The guy said that alone could make a big difference, and its only $20 so I figured I might as well go for it.
the filters are normally attached with hose clamps,just buy a k+n filter if ur that stuck on one of those and clamp it to the pipe,then try to resell the no-name cone filter to make a few bucks back.or just put the k+n drop in like u said if u really don't want to do a full intake. just about any one of those intakes should work they just might need a little modification to fit right,but nothing too difficult.
