aight, ive got the koni sport suspension kit (yellows and springs). i was wondering if anti-sway bars are going to improve my handling and what effect they may have.
Absolutely!!  They act to keep the car level through turns, keeping the tires flat on the road.
definitely a good investment
Yup.  I've got koni sport kit and 1" addco F/R, check my registry
Body roll is basically gone...
Now to get my poly bushings/control arms up front fixed so that I get my caster back in line.
(read:
http://www.j-body.org/forums/read.php?f=3&i=87027&t=87027 messed up the rear bushing on the control arm
hey squisher, u got some pics showing the koni kit drop??
thanks
Sorry, no.  No digital camera, I spent all my money on the car
I'll try and borrow one this weekend and get some posted up.  I've had a couple of requests.
^^^yay hopefully u can get some pics. thanks
I know its been awhile, but i would still like to see some pics
thanks
Sorry, kinda forgot.
Side shot:
Rear fender gap
Front Fender Gap (Still on my azenis...I miss those tires...)
Sleeper style, they don't see it coming that way.
Koni plus a 1 1/8" Front sway bar makes for awesome handling.  Just do go over a speed bump on an angle.  It feels like your driving a car with a solid front axle lol.
Ad1kTed 2 SpE3d and squisher00z24,
Thanks for posting up the pics! and also, did you guys measure before and after? I was wanting to know how much drop the springs give front and back.....
if anyone else has some pics with the koni kit, post them up please
thanks
No i didnt...its not too aggressive...the back is MUCH lower...the front almost looks very little lower..
it is hard to tell in the pics, but does it look lower in the back than front? like the rear is sagging?
thanks
I didn't measure, but I'd say about 2" drop in the back, maybe 1.5" in the front.  Back's not lower than the front, it's about the same now
Looks hawt IMO.  Much lower than that and it starts getting silly, not to mention you're getting your control arms out of their optimum position (paralell w/ ground) if you go any lower than this.
I should post up pics when I'm on my current racing rims (15x7" Fiero GT rims, don't laugh, 225/50/15's are sticky!).  Wide tires on 15s and 16s look dayum seksay with this suspension setup. (ok. 16's are sexy...15's are just ready to haul ass)  I never did like our cars with the really big wheels...17s are OK, but they just don't work (IMO) with anything bigger, not to mention the extra weight farther out from the center.
1 1/8" FRONT?  Dayum.  What are you using for rear?  I've got the Addco 1" front and rear.  The rear one is installed in addition to the factory one...drives pretty nice after that.
there is no "stock rear anti-sway bar" there may be a a stabilizer bar welded into the rear twist beam, however that does not contribute to negating body roll.
Cinny:
Uh...yeah there is.  I understand we have that solid twist-beam rear suspension, where basically the entire back end is one big swing arm, but that bar that goes across does twist.
The stabilizer you're talking about IS the stock sway bar (at least that's what I called it...).  (stabilizer != anti-sway bar?  I thought they served the same purpose, just different name)  IIRC, some of the base model packages (forget what years) didn't have that stabilizer, and it makes quite a bit of difference.  It's just integrated in the twist beam setup on the models that do have it.  It does negate body roll, a lot.  Especially with an after market bar.  The Addco bar mounts on the outside of it.  They effectively make that twist beam stiffer (less twisting, yes it is designed to twist so that the rear wheels have some independent motion) -- the end result is less body roll in the back.
If you run a search in this forum, somebody asked about if "sway bars" in the rear of our cars actually do anything.  Yes they are real rear sway bars, yes they do reduce body roll.  If you don't believe me, try it yourself or come ride in mine
To me it sounds more like a difference in terminology, in either case they serve the same purpose as far as I can tell.
^ if you're talking about that thin little pos thats welded inside the twist beam, i'd HARDLY call that a "real" sway bar.
