1998 Chevy Cavalier base model-
 For my horn to work i have to punch the steering wheel for it to work, Well sometimes it works and other times it doesn't. And right now it doesn't. When the horn would work on the passenger side of the car under the dash some thing would click. But now that it doesn't work i cant figure out what was clicking when it would work. Help please and thank u
There's a relay, check your radio fuse, see if its blown.
My 96 GT had the SAME problem.  I took your advise and punched it(praying the air bag wouldnt go off because of some fault.  You never know, right?  lawl), and now it works fine.
Other than that click.
It doesnt matter, my exhaust is 10X louder than my horn.  I was driving down the road one day and there was a deer in the middle of it.  I stopped dead in front of it.  It didn't even look at me the stupid bastard.
Anyways... i honked at it, it just looked at me.  Then i reved my engine and it took off like a raped ape.
I have a sissy horn.  allwell.  lawl
my radio works so its not the fuse. Have any other ideas what the problem could be.
Does your cig lighter work?  Check that fuse.  It might be the same as the radio, I forget.
Lanman31337 - Cavfire wrote:Does your cig lighter work?  Check that fuse.  It might be the same as the radio, I forget.
No its not.  Cig lighter is by itself.  I know this because i had to replace mine to use my GPS lol.
Ill check it out and get back to u on it. thanks a mill
my 00 is doing that too now, it used to work fine then i found out my fianc.. ex fiancee was cheating on me, well now its broken and i have to hit it in a certin spot or punch it to get it to work... didn't think to much of it till i got cut off by some ass hole in a 98 mustang
i couldnt even get the one to work on my '97 Z24, even punching it. then i found two problems, the thing that holds the wire inside the steeringwheel was broken, and the horn itself is crap. even when it is hooked up to the battery itself, it sounds like @!#$..
this is a video of it hooked up to my Acura
this was after taking about a gallon of water out of it.. now it just kinda clicks...
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/pbdoog0-ov4&hl=en&fs=1&rel=0"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/pbdoog0-ov4&hl=en&fs=1&rel=0" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
Dawson Schild wrote:WTF embed fail
HTML isn't allowed.
Dawson Schild wrote:why cant i edit that post??? WTF is wrong wit this site... :/
Nothing, you just don't know how to use it.
anyway, I'll guarantee most of these horn problems are due to the white thing holding the wire in being slightly broken.
Interior FAQ -
J-Body of Michigan -
