i would say a week or more to do it right and not look like walmart..
®â€îñg666™
You can remove almost your entire interior and still have a drivable car. As long as you have the gauge cluster, steering wheel & associated arms, driver's side seat & seatbelt, the car won't be out of commission.
Interior FAQ -
J-Body of Michigan -
If you want to remove the entire dash, the gauge cluster has to come out.
It can still be plugged in without the dash in the car.
Interior FAQ -
My posts do not say both things. Read it slower; you'll understand eventually.
You remove the gauge cluster in order to remove the dash (very large object, not the top of the dash), because the cluster sits in the dash. After the dash is removed, you can plug your cluster back in and it will work fine. You just need a place to mount it.
Interior FAQ -
