i have a small switch panel (two switches) which requires two screws (1/4" long) to be drilled into somewhere in my car to mount it... any suggestions as to where i can mount this? i want it to be out of the way, but not difficult to get to... the switches are for my interior(1) and exterior(2) neons.
i was thinking, about the following places, but dont know if the wires could be easily hidden
1. center console and drill the wires towards the front of the car hiding them all under my change holder so i can swap the fuses if needed and then from there, run them under the console to the wiring panel.
2. glovebox. i dont know how i would hide the wires from the glovebox, but i guess i could pull the dash pad off and hang it on the top side of the glovebox and put the wires through the top and run them back to the wire panel...
3. drivers side of the console... i like this idea, but i dont want the panel of switches just chillin there in the middle of nowhere.
4. Please toss out suggestions. or where you have your switches at
If they are small rocker switches I would put them in the little tray you get when you install an after market head unit in your car. Thats where I put my nitrous switches, nobody can see them and they are out of sight but easily acessable. Sorry I dont have a digi to take pics, mine got broken when I was in a car accident and I never got it replaced.
sounds like an idea, i need to replace my head unit sometime in the near future probably a summer project as well... thanks for the idea.
any others?
Jucie n' Boost (jucie pushrods wrote:If they are small rocker switches I would put them in the little tray you get when you install an after market head unit in your car. Thats where I put my nitrous switches, nobody can see them and they are out of sight but easily acessable. Sorry I dont have a digi to take pics, mine got broken when I was in a car accident and I never got it replaced.
little tray, i never got a little tray....just got something that holds a 1din headunit....and it kinda like curves in toward the car.....hmm....
but yea, where else can u put switches, i really wanna know, i want to know for like 4 switches, maybe more......idk....
i was considering fiberglassing is......but i've never fiberglassed before....
so....
im actually thinking about just building a box and keeping it under my drivers seat, i think that would be pretty sweet, out of sight from passengers, easily accessible and not easily damaged
any thoughts?
If you wanted them hidden, I would put them inside the center console. Only downfall would be you would have to open it to get at the switches. Depends on what you are using the switches for. Might bother you, might not. Other option is below the head unit, kinda under the dash where that fake cigarette tray thingy is.
1999 Grand AM SE (Beater Car)
1997 GMC Sierra
2007 Honda CBR 600RR
2005 Honda TRX450R
my cav has no cig tray, unless its that little dip bowl like thing... lol never could find a good use for that, but idk if the switches would look just chillin there. also i have no aftermarket headunit so i have to pass on that thought. thanks
Luke Heier wrote:Only downfall would be you would have to open it to get at the switches.
I had my switches in the center console for a long time; the biggest hassle I had was unplugging all the wiring when I needed to remove the console.
Now I have my switches in a panel on the lower dash. Much less hassle & fuss.
Interior FAQ -
J-Body of Michigan -
right now im thinking a 3" by 8" box for four switches and 4 led's to show me whats on and whats not.
like this
that's where i threw mine - it'll be a problem if you have power windows though
Shiba-I have an 01 and I noticed you have an 98. the hvac controls and the radios are switched on the dash between these years and when you install a 1 din headunit in a 2k+ j you get the little "pocket " I was talking about.
i like that one too... crap im in a pickle now...
I recently got a new digi cam so I snapped a pic 4 ya. Here is where I put my nitrous arming switch.
