Whats up guys,
Im preparing to do a performance N/A rebuild on my ecotec and im in need of some verrification on part numbers.
From what I can tell:
Main bearings: 12591092
Rod bearings: 21018825
Gasket set: 12992309 (complete)
Now the gasket set seems a little overkill to me. Gm says that the complete set is the best way to go because if you buy the gaskets for a rebuild individually, it will be more expensive. The gasket set though is 352$ which is a little expensive.
Does anyone know part #s for basicly rebuilding a short block?? Do I have to buy a complete gasket set??
And how about the main and rod bearings? Are those accurate?
The main bearing in the gm build book is listed as: 21018819 Whats the difference??
"Go Before Show Yo."
CARCUSTOMS.NET, THE BEST SERVICE ON THE ORG!!!
go to napa or arnold motor it will be cheaper from them than buying from GM
