My car won't start at all.....it doesn't even crank over.  I have removed the starter and I am about to go get it tested.  Can you guys think of anything it could be?  The battery is fine cuz it powers everything, just when I go to turn the ignition it won't crank over.  It ran two days ago, that is when I discovered a leak one of the hoses from the transmission to the radiator.  Since, then it hasn't been started.  When it did start is started fast, and right away.  This is beyond me......
a battery can have enough juice to power things and still not have enough to start the car...sounds to me like a bad battery, solenoid or starter...check the  terminals for corrosion or a broken cable if you changed the hose...also check for a blown fuse. hope this helps some
HONDAS ARE LIKE TAMPONS…EVERY PU**Y NEEDS ONE!
i agree, the first thing to always check when something electrical doesnt go at all is the fuse.
thanks guy, but it turned out to be the starter.....I checked all the fuses before I left for autozone, it was prolly just the solenoid on the starter.  But Autozone doesn't sell just the solenoids, so I had to buy a whole new starter......its okay though I like shiny things
