WEll finished putting in my engine in my z24.. automatic transmission. i have a big smile on my face cause after so long i was going to see it move. turn it on purrs like a kitten, all the gauges do not work hurmmm probably a fuse right ? i step on the brake and go to put it to gear . nothing does not move. stays in park. i tryed to put it in gear manually through the engine compartment but nothing......
my question is = could it be some sort of electrical problem ? is there anyway i did anything wrong when i married the transmission with the engine ? . would any electrical problem make it do something like this ? is my tranny gone ? i installed a mustang transmission a while ago and i had to turn the torque converter side to side to make it in all the way but this transmission torque converter just slit in all the way with out movement. i left fluid in the torque coverter .. any ideas help thanks.. this cavy is gonna be the end of me and my wallet.
Ohhh yeah i can hear the rpm's clim up super fast like half a second and its probably hitting 5500-6000 .. im thinking something to do with the torque converter ? ? ?? ? ? ? ?
Sounds to me like you didn't bolt the converter to the flex plate
Flex plate ? ? the flywheel ?
flywheel:manual::flexplate:automatic (in standard SAT analogy format
fortune cookie say:
Yeah i connected the Flexplate to the torque converter the three bolts. i mean everything should be right but i just checked the fuses for the gauges and well all of them are functioning. what could be causing this ? what part of the electrical system if at all ? thanks im just anxious to get this car going .. thanks
OK i jacked up the dad put it in park and the tires still spin ? im thinking is in neutral.. now anyone know what part of the tranny is F'ed up ?
