2.2L OHV upgrades - Performance Forum
2.2L OHV upgrades
Sunday, December 10, 2006 11:00 AM
I have a 1997 2.2L OHV non-ecotec cavalier in which i am looking to do some engine work....I was wondering what kinds of things i can do because i am only 17 but would like to know as much as i can about my engine....i dont know much about things like cams and engine upgrades....please enlighten me...thanks JBO
Re: 2.2L OHV upgrades
Sunday, December 10, 2006 11:05 AM
easiest stuff to start out wiht would be:
intake
header
exhaust
Sunday, December 10, 2006 11:58 AM
sorry, should have added that i have an intake and a pacesetter exhaust...but headers does sound good, any suggestions...?
Sunday, December 10, 2006 12:05 PM
pacesetter ceramic coated header is good. then there is engine mounts, pulley set, tranny mounts if you have a 5 speed
Sunday, December 10, 2006 8:31 PM
how bout j body performance cam and lifters and rods adds about 15 whp but you will need to tune your car then
Sunday, December 10, 2006 8:47 PM
x2
Biggest hurdle you are going to have is fuel delivery. Since the injectors are side-feed, you are limited to stock injectors.
If you add anything that will require more fuel (for example, forced induction) you are either going to have to swap engines to the 98+ 2200 or custom fab a top feed conversion.
Monday, December 11, 2006 4:14 PM
frew wrote:how bout j body performance cam and lifters and rods adds about 15 whp but you will need to tune your car then
stay away from JBP with a 2.2L OHV
If you want to have some 'in-engine' experience, search for MadJack's rocker thread
fortune cookie say:
Monday, December 11, 2006 7:19 PM
really what did you have a bad expereicne with j body perf or what? Im not tryin to sound liek an @!#$ i really wanna know
Tuesday, December 12, 2006 2:21 AM
frew, The JBP cams are over priced regrinds. Crane, Comp, Isky, etc can do just as good or better regrind for much less. Discuss with you favorite cam manufacturer about what you plan to do with the car and have them do a regrind for you on a stock cam you provide. These motors respond well to profiles designed for Small Block Chevys.
The JBP springs are too high of a rate, which breaks other parts, i.e. lifters and/or pushrods.
Nick, as for other mods to do, the header should be next. After that, look into making the head flow better, which is the biggest restriction on these motors. Roller rocker arms will help, here's a link to the 2.2L/2200 Rocker arm thread.
Also, look into the Patriot Performance 2.2L Cylinder Head, it's a really nice piece. I know Ryne at Team Vision Racing can get them for you, as well as a few other retail sites mention on JBO. You'll be stuck with stock lift values with the assembled head, which will be about .480" at the stock rev limit of 6000 rpm (you could go higher, but I don't reccomend it, on stock springs).
