2.3 HO intake Mani swap - Performance Forum
Friday, August 10, 2007 6:23 PM
I know this has already been brought up but im down in my basment doin the swap as we type. how go u swap a HO intake mani with a car that has EGR. Thanks. im sry this has been brought up again
99z for 2015.. I'm back bitches
Re: 2.3 HO intake Mani swap
Friday, August 10, 2007 6:32 PM
u need to go down to GM, get yourself an "EGR block off plate" they usually run anywhere from $6-$20 depending on the deal you can make with your dealer. MAKE SURE YOU USE SHORTER BOLTS-if you use the stock EGR bolts (alan headed) you WILL bottom them out and its not going to work.
just leave the unit un-pligged and hide the sensor plug somewhere out of the way.
u can either deal with your CEL being on all the time, or get yourself your own hptuners unit and delete the CEL permanatly from your computer, or send it out to get tuned. i used shifted tuning, look up ron beyer (shifted) on here, he can help you with all your computing needs.
Friday, August 10, 2007 6:35 PM
thanks man. can i tap in to the 2.3 ho mani and make that EGR work?
Friday, August 10, 2007 6:44 PM
it has been done though not easy to do
http://www.j-body.org/forums/read.php?f=2&i=361412&t=361412#361412
http://www.j-body.org/forums/read.php?f=2&i=354144&t=354144#354144
i felt froggy and did the search, i have been looking to do this but just decided to delete the trouble code when it does bother me. best of luck
Friday, August 10, 2007 10:05 PM
Thanks guys for all the great info. now i have another ? where do u put the pipe for the br8k booster and how do i modify it? just cut it to the right size. thank you.
Saturday, August 11, 2007 5:55 AM
mine isnt the best way of doing it but it works. here a pic for ya.
now mine doesnt have a working EGR setup yet. in the process
Saturday, August 11, 2007 8:38 AM
thanks man. im almost done im goin to get the swap done tonight after work. thanks guys for all the great info it help alot. ill have pics. by nxt tues. (only day off)
Saturday, August 11, 2007 10:50 AM
For the brake booster, just cut it back far enough and run a hose.
-M
Saturday, August 11, 2007 7:00 PM
Whats up guys? i got another quick ? how do i make the stock thottle cable work. (I really dont want to Fab enything)
Saturday, August 11, 2007 7:15 PM
it really depends on the TB you are using as to how you will ho abouts doing it. I modified the 2.4 throttle bracket and throttle wheel to fit on the 2.3 TB and to make it fit in the tighter constraints of the automatic. All I used was a dremel tool and cutoff wheel. The only pictures i have of it arent great but if you want i can try and post them up for you.
Saturday, August 11, 2007 7:23 PM
Thanks man. the pictures will be better then no pictures it might help all the other info you guys have gave me has helped out millions.
Saturday, August 11, 2007 7:26 PM
the cable isnt long enough to get to the TB. i was thinking about turning that cable box around. with out puttin to much stress on that cable
Saturday, August 11, 2007 7:31 PM
Dont worry, it has been pulled back down and cleaned and painted some but you can see how i cut the throttle bracket to make it fit around the "ridge" on the auto. now again i used the 2.4 throttle wheel and modified 2.4 throttle bracket on the 2.3 TB and so far put about 7,000 miles on it with no issue. there is probably a better way of doing it such as using the parts of a 95 cavy with 2.3 but i couldn't find one in the yards near me so i made it work. best of luck, and chose the way that makes it the most comfortable to you. now if you have cruise i can explain how i did it later.
Saturday, August 11, 2007 7:33 PM
Thanks man!
Saturday, August 11, 2007 10:04 PM
Now the batt. is hittin the cables. how do i get around that
Sunday, August 12, 2007 1:05 AM
Whats up guys i got good news and bad news the swap is complete but when i start it it jumps and cherks i dont know why
i check all the injecters and there fine what could it be? thanks
Sunday, August 12, 2007 8:42 AM
it kind of sounds like its missing? but i dont know what it is. and it also kind of smells like its not fireing right also.
Sunday, August 12, 2007 9:57 AM
check for vacum leaks, that was one issue i ran into mainly because the old guy at the parts store sold me bolts that were too short. look for air leaks and make sure all the hoses are in the right spots, especially the MAP sensor. best of luck.
Sunday, August 12, 2007 10:37 AM
Thanks man. im about to post some pics of it on this tread so you can check out my progress
Sunday, August 12, 2007 1:12 PM
Ok im back. i started the car again and it sounds like its missing idk Y. could it be a vac. leak or do i need to get a gasket. idk y its doin this. all the injecters are in? thanks
Sunday, August 12, 2007 2:46 PM
Are you useing gaskets on both the manifold and the t/b? I dought its the injectors. Just make sure u have all vacum lines pluged in and the other
ones caped off that arent being used. Whats it ideling at?
Sunday, August 12, 2007 4:17 PM
it idels around 12oo. i have to order a flange. thats what it is. Thanks guys for helpin me out with this.
Sunday, August 12, 2007 4:22 PM
one thing to think about mine is running good unflanged. i just used "orange" hi-temp RTV and have no problems. now the adapter flange is on the list to get, amongst other things, just really saying it can work without. but being a high idle check and make sure the throttle cable isnt holding the TB butterfly valve open also check the cruise control cable for same if you have it. then check your vacum lines and especially the brake booster lines for leaks. the only time i ever had a vacum leak large enough to raise the idles it was the brake booster line that did it. well again best of luck.
Sunday, August 12, 2007 4:42 PM
Here are some pictures of the swap!
Sunday, August 12, 2007 4:52 PM
pics not worky. how you tryin to load them?
