Grumpy McGrumpster(BIGGSZ24) wrote:Called the dealer and they said they did not have the specs. in their computer(BS)I have had many here say 12mm,15mm head size and anywhere from 40mm,60mm and 100m in length.I will more than likely get them from the dealer but if someone here has the correct answer then I can get them cheaper.
Quiklilcav wrote:Grumpy McGrumpster(BIGGSZ24) wrote:Called the dealer and they said they did not have the specs. in their computer(BS)I have had many here say 12mm,15mm head size and anywhere from 40mm,60mm and 100m in length.I will more than likely get them from the dealer but if someone here has the correct answer then I can get them cheaper.
The two different sizes your hearing (12mm and 15mm) are because the size of the shaft is 12mm, and the size of the head is 15mm. I would bet money on them being 12mm 1.75 thread. If you've already removed the part that's left, take it to the hardware store and match it. For the length, I seriously doubt it will be 100mm. It doesn't need that kind of depth. That's almost 4". It could be 60mm, though. If the bolt goes right through the bottom piece where it threads into, I'd go with the 60mm, as long as there is nothing to worry about it running into. Looking at the picture again, I would actually say there's a good chance they are 60mm, because the top part of the mount is pretty thick.
The other thing is that you can always get one bolt of low grade and see how it fits. A standard strength 12mm, 1.75, 40-60mm bolt will run you less than a dollar. If that fits properly, then get the high strength.
If your local dealer is BS'ing you, just tell them you'll get your parts elsewhere. They have the info.
Quiklilcav wrote:So in reality, that 60mm length may or may not have worked. If the 55mm just about bottoms out in the hole, the 60 would not have allowed you to tighten it down, and you'd end up with the same problem.
